Kay,
I found the issue.
Not all the macros were being passed to the main display from the command line. I had to quote the entire string of macros on the command line.
Tony
>I succeeded in passing macros on the command line, now I want to open a generic display from this top level display and selectively assign one of the macros. I am using
an action button to open the related display. I have tried assigning the generic macro to one of macros passed from the command line (GENERIC_MACRO = $(MACRO1)), in the related display dialog box, but the macro doesn’t expand. The new screen shows the value
of GENERIC_MACRO as $(MACRO1) rather than the value of $(MACRO1).
>How can accomplish this?
In a display, define MACRO1=Value 1, MACRO2 = Value 2.
Then add for example a label with text "You picked $(PICK)".
I can now open that display from the command line with one of
-resource file:/path/to/file?PICK=Something
-resource file:/path/to/file?PICK=$(MACRO1)
-resource file:/path/to/file?PICK=$(MACRO2)
and as a result the screen opens with "You picked Something", "You picked Value 1" respectively "You picked Value 2".
In the last case, when I open the context menu on the display to open the display information dialog, then check the "Macros" tab, it contains:
-Kay
- Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line D Willimoto via Tech-talk
- How do I pass a macro to a CSS Phoebus screen at startup from the command line Pietryla, Tony via Tech-talk
- Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line Kasemir, Kay via Tech-talk
- Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line Pietryla, Tony via Tech-talk
Re: EPICS driver for Xilinx ZYNQ ultrascale FPGA firmware PL register read write Michael Davidsaver via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
