1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Pietryla, Tony" <[email protected]>
Date: Tue, 1 Dec 2020 15:53:03 +0000
> I am trying to open a CSS Phoebus screen and I want to pass the value of a macro from the command line at startup. How can I do this?
Amongst your options:
Add the file and macros to the command line,
phoebus.sh -resource file:/path/to/file?MACRO1=value+1&MACRO2=ab
Or create predefined macros in a my_settings.ini file:
 org.csstudio.display.builder.model/macros=<EXAMPLE_MACRO>Value from Preferences</EXAMPLE_MACRO>
.. and then start with that settings file:
phoebus.sh -settings /path/to/my_settings.ini
Or define the macro as environment variables, since macros fall back to them
export EXAMPLE_MACRO=SomeValue
export ANOTHER_MACRO=SomeOtherValue
phoebus.sh
Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line Pietryla, Tony via Tech-talk
Prev: Re: Supported 'Scopes? Hu, Yong via Tech-talk
Next: Re: Looking for help on PMD101 EPICS driver Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: How do I pass a macro to a CSS Phoebus screen at startup from the command line Pietryla, Tony via Tech-talk
Next: Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line Pietryla, Tony via Tech-talk
