1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line
From: D Willimoto via Tech-talk <[email protected]>
To: "Pietryla, Tony" <[email protected]>
Date: Tue, 8 Dec 2020 04:02:59 +0900
Hi there,
I’m working on a similar issue.
Is there a general guide/manual for Phoebus that I’m just not seeing?
Appreciate it if someone can point me in the right direction.
Best,
Dave
On Tue, Dec 8, 2020 at 3:44 AM Pietryla, Tony via Tech-talk <[email protected]> wrote:
Kay,
I found the issue.
Not all the macros were being passed to the main display from the command line. I had to quote the entire string of macros on the command line.
Tony
On 12/7/20, 11:35 AM, "Kasemir, Kay" <[email protected]> wrote:
Hi:
>I succeeded in passing macros on the command line, now I want to open a generic display from this top level display and selectively assign one of the macros. I am using an action button to open the related display. I have tried assigning the generic macro to one of macros passed from the command line (GENERIC_MACRO = $(MACRO1)), in the related display dialog box, but the macro doesn’t expand. The new screen shows the value of GENERIC_MACRO as $(MACRO1) rather than the value of $(MACRO1).
>How can accomplish this?
This works for me:
In a display, define MACRO1=Value 1, MACRO2 = Value 2.
Then add for example a label with text "You picked $(PICK)".
I can now open that  display from the command line with one of
 -resource file:/path/to/file?PICK=Something
 -resource file:/path/to/file?PICK=$(MACRO1)
 -resource file:/path/to/file?PICK=$(MACRO2)
and as a result the screen opens with "You picked Something", "You picked Value 1" respectively "You picked Value 2".
In the last case, when I open the context menu on the display to open the display information dialog, then check the "Macros" tab, it contains:
MACRO1 = Value 1
MACRO2 = Value 2
PICK = $(MACRO2)
-Kay
Re: [EXTERNAL] Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line Kasemir, Kay via Tech-talk
How do I pass a macro to a CSS Phoebus screen at startup from the command line Pietryla, Tony via Tech-talk
Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line Pietryla, Tony via Tech-talk
Prev: RE: EPICS driver for Xilinx ZYNQ ultrascale FPGA firmware PL register read write Kunjir, Shriraj via Tech-talk
Next: Re: EPICS driver for Xilinx ZYNQ ultrascale FPGA firmware PL register read write Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line Pietryla, Tony via Tech-talk
Next: Re: [EXTERNAL] Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line Kasemir, Kay via Tech-talk
