I see the problem. The code has a main.cpp which creates a linked list of controller port names, and then searches it. Controllers get added to that list with a call to addToList().
This is a search for addToList in the code.
corvette:~/scratch/EZ4axis>git grep addToList
allmotionApp/src/allmotion.h:bool addToList(const char *portName, almController *drv);
allmotionApp/src/almController.cpp: if (!addToList(portName, this)) {
allmotionApp/src/main.cpp:bool addToList(const char *portName, almController *drv)
The problem appears to be that almController.cpp calls addToList to add the new controller to the list, but almEZ4Controller.cpp does not.
This whole mechanism of maintaining a linked list of controller names in the code is obsolete. It should be replaced with a call to findAsynPortDriver() which is part of asyn.
That is what these motor drivers do:
corvette:~/devel/motor/modules>find . -name '*.cpp' -exec grep -H findAsynPortDriver {} \;
./motorScriptMotor/scriptMotorApp/src/ScriptMotorDriver.cpp: ScriptMotorController *pC = (ScriptMotorController*) findAsynPortDriver(ScriptMotorName);
./motorScriptMotor/scriptMotorApp/src/ScriptMotorDriver.cpp: ScriptMotorController* controller = (ScriptMotorController*) findAsynPortDriver(port);
./motorMicos/micosApp/src/SMCcorvusDriver.cpp: pC = (SMCcorvusController*) findAsynPortDriver(SMCcorvusPortName);
./motorMicos/micosApp/src/SMChydraDriver.cpp: pC = (SMChydraController*) findAsynPortDriver(SMChydraPortName);
./motorMicroMo/microMoApp/src/MVP2001Driver.cpp: pC = (MVP2001Controller*) findAsynPortDriver(MVP2001Name);
./motorSmarAct/smarActApp/src/smarActMCSMotorDriver.cpp: pC = (SmarActMCSController*) findAsynPortDriver(controllerPortName);
./motorSmarAct/smarActApp/src/smarActSCUMotorDriver.cpp: pC = (SmarActSCUController*) findAsynPortDriver(controllerPortName);
./motorAMCI/amciApp/src/ANF2Driver.cpp: pC = (ANF2Controller*) findAsynPortDriver(ANF2Name);
./motorNewport/newportApp/src/AG_UC.cpp: pC = (AG_UCController*) findAsynPortDriver(AG_UCName);
./motorNewport/newportApp/src/XPSController.cpp: pC = (XPSController*) findAsynPortDriver(XPSName);
Sent: Tuesday, December 8, 2020 4:06 PM
To: Mark Rivers
Subject: Re: multiple USB devices in Asyn
Hi Mark,
Someone gave me the IOC code, but I discovered it on GitHub.
https://github.com/klauer/EZ4axis
I'll clone this repo and see if it is the same as what I have. As you can see, it is fairly old, and Ken doesn't remember much about it. Kaz Gofron is using it here, which is how I got onto it. He's not around much for the past month or two, so I haven't got much from him.
Pete.
Sent: Tuesday, December 8, 2020 4:23 PM
To: Siddons, David <[email protected]>
Subject: RE: multiple USB devices in Asyn
Hi Pete,
From the output you sent it creates the first controller with no messages.
almCreateEZ4Controller("ALM1", "IP1", "1", 4, 200, 500)
Firmware version: EZController AllMotion V7.50h6 5-8-13
Limit thresholds 6150,6150,6150,6150,6150,6150,6150,6150
When it creates the second controller it prints the message “AllMotion: allmotion on port ALM2 not found”, but then it seems to work, because it correctly prints the firmware version and the limit thresholds.
almCreateEZ4Controller("ALM2", "IP2", "2", 4, 200, 500)
So my question is what code is printing the message “AllMotion: allmotion on port ALM2 not found”?
- It is not printed in the driver code you sent me, the string “found” does not exist in that file.
- It is not printed in the asynMotorController or asynPortDriver base classes, because those would print timestamps.
It looks like you must have some additional code you did not send. Do you have an additional file that does the iocsh registration, for example?
Sent: Tuesday, December 8, 2020 3:02 PM
To: Mark Rivers <[email protected]>
Sure:
#!../../bin/linux-x86_64/ez4axis
epicsEnvSet("ENGINEER", "siddons")
epicsEnvSet("LOCATION", "740 various?")
# epicsEnvSet("EPICS_CA_AUTO_ADDR_LIST", "NO")
# epicsEnvSet("EPICS_CA_ADDR_LIST", "10.3.0.255")
< envPaths
epicsEnvSet("IOC","iocez4axis")
epicsEnvSet("TOP","/home/peter/det_grp/fy20/fffi/ez4axis/EZ4axis-master/ez4axis_example")
epicsEnvSet("SUPPORT","/home/peter/synApps/support")
epicsEnvSet("ASYN","/home/peter/synApps/support/asyn-R4-41")
epicsEnvSet("ALLMOTION","/home/peter/det_grp/fy20/fffi/ez4axis/EZ4axis-master/ez4axis_example/../")
epicsEnvSet("MOTOR","/home/peter/synApps/support/motor-R7-2-1")
epicsEnvSet("AUTOSAVE","/home/peter/synApps/support/autosave-R5-10-2")
epicsEnvSet("CALC","/home/peter/synApps/support/calc-R3-7-4")
epicsEnvSet("EPICS_BASE","/home/peter/epics/base")
dbLoadDatabase("../../dbd/ez4axis.dbd",0,0)
ez4axis_registerRecordDeviceDriver(pdbbase)
epicsEnvSet(EZ_IP , "10.3.2.61")
epicsEnvSet(EZ_PORT , 4001)
epicsEnvSet(CtlSys , "FFFI")
epicsEnvSet(Sys , "FFFI")
epicsEnvSet(CntlDev1 , "Ez4:1")
epicsEnvSet(CntlDev2 , "Ez4:2")
epicsEnvSet("IOCNAME", "ez4axis-1") # set by softioc init.d script
epicsEnvSet("IOC_P", "FFFI{IOC:ez4axis-1}")
## NOTE: RS485 address must match up with the address selected on the device with its address switch:
epicsEnvSet(ALM_ADDR1, 1)
epicsEnvSet(ALM_ADDR2, 2)
## Load record instances
dbLoadRecords("/home/peter/det_grp/fy20/fffi/ez4axis/EZ4axis-master/ez4axis_example/..//db/ez4axis.db","Sys=FFFI,Dev={Ez4:1},PORT=ALM1,ADDR=0")
dbLoadRecords("/home/peter/det_grp/fy20/fffi/ez4axis/EZ4axis-master/ez4axis_example/..//db/ez4axis.db","Sys=FFFI,Dev={Ez4:2},PORT=ALM2,ADDR=1")
dbLoadTemplate("motors8.sub")
dbLoadRecords("/home/peter/det_grp/fy20/fffi/ez4axis/EZ4axis-master/ez4axis_example/db/example.db")
Bad character '$' in record name "$(P)allstop"
$(P)allstop.FLNK Has unexpanded macro
Can't set "$(P)allstop.FLNK" to "$(P)KILL_ALL"
Error at or before ")" in file "/home/peter/det_grp/fy20/fffi/ez4axis/EZ4axis-master/ez4axis_example/db/example.db" line 2
# drvAsynIPPortConfigure 'port name' 'host:port [protocol]' priority 'disable auto-connect' noProcessEos
drvAsynSerialPortConfigure("IP1", "/dev/ttyUSB0", 0, 0, 0)
asynSetOption("IP1", -1, "baud", "115200")
asynSetOption("IP1", -1, "bits", "8")
asynSetOption("IP1", -1, "parity", "none")
asynSetOption("IP1", -1, "stop", "1")
asynSetOption("IP1", -1, "clocal", "Y")
asynSetOption("IP1", -1, "crtscts", "N")
drvAsynSerialPortConfigure("IP2", "/dev/ttyUSB1", 0, 0, 0)
asynSetOption("IP2", -1, "baud", "115200")
asynSetOption("IP2", -1, "bits", "8")
asynSetOption("IP2", -1, "parity", "none")
asynSetOption("IP2", -1, "stop", "1")
asynSetOption("IP2", -1, "clocal", "Y")
asynSetOption("IP2", -1, "crtscts", "N")
# almCreateController(AllMotion port name, asyn port name, RS485 address,
# Number of axes, Moving poll period (ms), Idle poll period (ms))
#asynSetTraceMask("ALM1", -1, 0x01)
#asynSetTraceIOMask("IP1", -1, 0x0)
# asynSetTraceMask("ALM1", -1, 0x0)
# asynSetTraceMask("IP1", -1, 0x0)
cd /home/peter/det_grp/fy20/fffi/ez4axis/EZ4axis-master/ez4axis_example/
#dbLoadRecords("$(EPICS_BASE)/db/save_restoreStatus.db", "P=$(IOC_P)")
#save_restoreSet_status_prefix("$(IOC_P)")
#set_savefile_path("${TOP}/as/save","")
#set_requestfile_path("$(EPICS_BASE)/as/req")
#set_requestfile_path("${TOP}/as/req")
#system("install -m 777 -d ${TOP}/as/save")
#system("install -m 777 -d ${TOP}/as/req")
#set_pass0_restoreFile("allmotion_pass0.sav")
#set_pass0_restoreFile("ioc_settings.sav")
#set_pass1_restoreFile("allmotion_pass1.sav")
#set_pass1_restoreFile("ioc_pass1_settings.sav")
iocInit()
Starting iocInit
## EPICS R3.15.6
## EPICS Base built May 2 2019
Warning: Duplicate EPICS CA Address list entry "192.168.1.255:5065" discarded
#makeAutosaveFileFromDbInfo("$(TOP)/as/req/allmotion_pass0.req", "autosaveFields_pass0")
#makeAutosaveFileFromDbInfo("$(TOP)/as/req/allmotion_pass1.req", "autosaveFields_pass1")
#create_monitor_set("allmotion_pass0.req", 10, "")
#create_monitor_set("allmotion_pass1.req", 10, "")
# caPutLogInit("ioclog.cs.nsls2.local:7004", 1)
# cd ${TOP}
dbl > ./records.dbl
# system "cp ./records.dbl /cf-update/$HOSTNAME.$IOCNAME.dbl"
epics>
From: Mark Rivers <[email protected]<mailto:[email protected]>>
Sent: Tuesday, December 8, 2020 3:52 PM
To: Siddons, David <[email protected]<mailto:[email protected]>>
Cc: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>>
Can you send the complete output when you start the IOC?
From: Siddons, David <[email protected]<mailto:[email protected]>>
Sent: Tuesday, December 8, 2020 2:49 PM
To: Mark Rivers <[email protected]<mailto:[email protected]>>
Hi Mark,
Here is the code. I tried to send the whole IOC, but your mailer rejected it.
Pete.
Sent: Tuesday, December 8, 2020 2:36 PM
Hi Pete,
Where is the source code containing this driver?
almCreateEZ4Controller("ALM1", "IP1", "$(ALM_ADDR1)", 4, 200, 500)
From: Tech-talk <[email protected]<mailto:[email protected]>> On Behalf Of Siddons, David via Tech-talk
Sent: Tuesday, December 8, 2020 1:13 PM
To: [email protected]<mailto:[email protected]>
Subject: multiple USB devices in Asyn
I have a setup with two identical USB devices. They connect as ttyUSB0 and ttyUSB1. I tried to set up an asyn interface using the following commands:
# almCreateController(AllMotion port name, asyn port name, board address,
almCreateEZ4Controller("ALM2", "IP2", "$(ALM_ADDR2)", 4, 200, 500)
This fails, saying port ALM2 cannot be found. If I try to connect the second one also to ALM1, it complains that ALM1 is already registered.
If I comment out the first device, the second one (with port ALM2) comes up fine. How should I be doing this?
Pete.
- multiple USB devices in Asyn Siddons, David via Tech-talk
- RE: multiple USB devices in Asyn Mark Rivers via Tech-talk
- Re: multiple USB devices in Asyn Siddons, David via Tech-talk
serial IOC connection problem Ivashkevych, Oksana via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
