Hi Mark,
Yes, this is exactly what I did , and it looks like I forgot to remove asynSetTraceMask( "FTS",0,0).
Oksana
[oksana@xf16id-babyioc1 ftsioc]$ vim st.cmd
[oksana@xf16id-babyioc1 ftsioc]$ ../../bin/linux-x86_64/ftsioc st.cmd
#!../../bin/linux-x86_64/ftsioc
< envPaths
epicsEnvSet("IOC","ftsioc")
epicsEnvSet("TOP","/home/oksana/ftsioc")
epicsEnvSet("SUPPORT","/opt/epics/support")
epicsEnvSet("ASYN","/opt/epics/support/asyn")
epicsEnvSet("CALC","/opt/epics/support/calc")
epicsEnvSet("STREAM","/opt/epics/support/StreamDevice")
epicsEnvSet("DEVIOCSTATS","/opt/epics/support/iocStats")
epicsEnvSet("AUTOSAVE","/opt/epics/support/autosave")
epicsEnvSet("EPICS_BASE","/opt/epics/epics-base")
epicsEnvSet("STREAM_PROTOCOL_PATH", "../../ftsiocApp/Db")
epicsEnvSet("PREFIX", "XF:16IDC-ES:LIX")
epicsEnvSet("FTS_IP", "10.16.2.195:49151 HTTP")
epicsEnvSet("PORT", "FTS")
dbLoadDatabase("../../dbd/ftsioc.dbd",0,0)
ftsioc_registerRecordDeviceDriver(pdbbase)
drvAsynIPPortConfigure("FTS", "10.16.2.195:49151 HTTP"
## Load record instances
dbLoadRecords("../../db/fts.db","P=XF:16IDC-ES:LIX,R={FTS:2},PORT=FTS,user=oksana")
#asynSetTraceMask( "FTS",0,255)
iocInit()
Starting iocInit
## EPICS R7.0.3.1
## EPICS Base built Dec 1 2020
#asynSetTraceMask( "FTS",0,0)
## Start any sequence programs
#seq sncftsioc,"user=oksana"
epics> dbl
[oksana@xf16id-babyioc1 Db]$ more fts.proto
Timeout=10000;
Terminator = "";
read{
MaxInput = 16;
out "\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00%0.2r\x00\x00";
in "\x12\x34%(A)02r%(B)2r%(C)2r%(D)2r%(E)2r%(F)2r%(G)2r";
readCalibration {
MaxInput = 24;
out "\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00";
in "\x12\x34%(A)01r%(B)01r%(C)04r%(D)04r%(E)02r%(F)02r%(G)02r%(H)02r%(I)02r%(J)02r";
disconnect;
@init {
> -----Original Message-----
> From: Mark Rivers <[email protected]>
> Sent: Wednesday, December 09, 2020 3:48 PM
> To: Ivashkevych, Oksana <[email protected]>
> Cc: [email protected]
> Subject: Re: serial IOC connection problem
> Hi Oksana,
> Just to be clear, did you add HTTP to the drvAsynIPPortConfigure command,
> and remove the "disconnect" commands from the protocol file?
> Mark
> ________________________________
> From: Ivashkevych, Oksana <[email protected]>
> Sent: Wednesday, December 9, 2020 2:35 PM
> To: Mark Rivers
> Subject: RE: serial IOC connection problem
> Hi Mark,
> Thank you very much!
> Not a single squeak!
> I may suggest considering adding "164.54.17.43:5186 HTTP" to the list of
> examples in the link you shared.
> Thanks again,
> Oksana
> > Sent: Wednesday, December 09, 2020 2:15 PM
> > Hi Oksana,
> > It may be that this device wants to just do a single transaction per
> > connection. That is how Web servers work.
> > drvAsynIPPort supports that mode of operation directly.
> > https://urldefense.com/v3/__https://epics-
> > modules.github.io/master/asyn/R4-
> 41/asynDriver.html*drvAsynIPPort__;Iw!!P4SdNyxKAPE!Sz1Tm08wfhCbs3_
> > mnZgFXMFrf7-JRdetWpdz-RbQ7TG0ozHVy-fgl3g3QhaCrw$
> > You need to change this line:
> > drvAsynIPPortConfigure("FTS", "10.16.2.195:49151")
> > to this:
> > drvAsynIPPortConfigure("FTS", "10.16.2.195:49151 HTTP")
> > Once you do that I think you can remove the "disconnect" commands from
> > the protocol file.
> > If you still have trouble please turn on ASYN_TRACEIO_DRIVER for the
> > IP port and send the output.
> > Mark
> > From: Tech-talk <[email protected]> on behalf of
> > Ivashkevych, Oksana via Tech-talk <[email protected]>
> > Sent: Wednesday, December 9, 2020 12:51 PM
> > To: [email protected]
> > Subject: serial IOC connection problem
> > Hello,
> > I have been asked to port an existing Serial IOC for a Force Torque
> > Sensor from ATI from one server (Debian 7 with Debian packages dated ~
> > at least 5 years ago) to CentOS 7.
> > CentOS 7.7.1908; base R7.0.3.1; asyn R4-37; SerialDevice master.
> > After the ported recompiled IOC reported unrecoverable connection
> > error, I have created a brand new IOC using the latest makeBaseApp.pl
> script.
> > Errors became more dynamic, and I do see some readings, when IOC does
> > manage to connect successfully. I have browsed the Tech Talk and found
> > a related discussions about connecting/disconnecting. Protocol file of
> > this IOC does connects/disconnects after every read and is very
> > simple. I only can guess why the developer made this decision, I am
> > sure it was an unavoidable compromise. I did add asynSetTraceMask
> > call which changes temporarily the dynamic of the errors. Logs and proto
> are attached.
> > In summary: I have two iocs accessing same device: the old one running
> > on Debian 7, and the new on running CentOS 7. The old one works
> > without problem the new on reports connection errors and does manage
> > to read something at the frequency ~30 times slower than 0.1 expected
> > scan. I am out of my own ideas, and would appreciate help from the
> community.
> > Thank you,
> > Oksana
- Re: serial IOC connection problem Mark Rivers via Tech-talk
- serial IOC connection problem Ivashkevych, Oksana via Tech-talk
- RE: serial IOC connection problem Ivashkevych, Oksana via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
