Subject: Re: ioc startup files not installed to INSTALL_LOCATION
To: Felix Krämer <[email protected]>
Cc: Talk EPICS Tech <[email protected]>
Date: Mon, 14 Dec 2020 10:31:38 -1000
Hi Felix,
Some solutions to package applications have been discussed here (in the debian context): https://epics.anl.gov/tech-talk/2018/msg02078.php
I agree with you, it would be great to have some generic rules in EPICS base supporting both rpm and debian packages. I suspect the differences
are great enough this becomes very messy.
-Matt
On Mon, Dec 14, 2020 at 6:23 AM Felix Krämer via Tech-talk <[email protected]> wrote:
Hi all,
Currently, I do some contractor work for Gemini for a new Application
Development Environment based on RPM.
In this context, I am working on one part of it to provide a framework
for softIOC installation, everything readily set up with conserver
configuration, procServ etc. after installing a respective softIOC RPM.
I do this development work based on a makeBaseApp.pl generated softIOC
example from the EPICS Application Developer's Guide (
https://epics.anl.gov/base/R3-15/6-docs/AppDevGuide/GettingStarted.html#x3-60002.2
). For installing EPICS software using RPM we have to _relocate_
installed binaries, scripts etc. This works well, principally, but
regarding the example softIOC there do arise a few questions:
(1) The startup file under iocBoot (st.cmd) is not installed anywhere.
If INSTALL_LOCATION is not redefined, then this is not a problem, but if
I want to keep the sources distinct from the product, this seems not to
be consequent. I changed the Makefile from
TOP = ../..
include $(TOP)/configure/CONFIG
ARCH = $(EPICS_HOST_ARCH)
TARGETS = envPaths
include $(TOP)/configure/RULES.ioc
to
TOP = ../..
TARGETS = envPaths
SCRIPTS_IOC_Linux += st.cmd
to install the st.cmd to the binary install dir, at least. Additionally,
I set IOCS_APPL_TOP in CONFIG_SITE to the install location to let
envPaths look right. This works so far. Is this the way to go?
In this context it might also be an idea to create a new template
directory for makeBaseApp.pl and point to it using the -T option. I'd
rather use the EPICS original ones, though, to have no adaption work
with future versions.
(2) Another option I thought about would be to define a User Created
File type
https://epics.anl.gov/base/R3-15/6-docs/AppDevGuide/BuildFacility.html#x5-1570004.6.35
), e.g. a FILE_TYPE IOCBOOT which would install this st.cmd to a
INSTALL_IOCBOOT = $(INSTALL_LOCATION)/iocBoot/.... directory, for
example. But same here: it's sort of 'proprietary' to do things like
these and such special solutions might be incompatible with future
versions of EPICS.
Or do I think completely in the wrong direction and there is already a
mechanism  in place which to install the startup files to
INSTALL_LOCATION which I simply do not see?
Any help or ideas as well as confirmation appreciated.
Felix
Re: ioc startup files not installed to INSTALL_LOCATION Jeong Han Lee via Tech-talk
ioc startup file installation Felix Krämer via Tech-talk
ioc startup files not installed to INSTALL_LOCATION Felix Krämer via Tech-talk
Prev: PVXS initial release (0.1.0) Michael Davidsaver via Tech-talk
Next: RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Prev: ioc startup files not installed to INSTALL_LOCATION Felix Krämer via Tech-talk
Next: Re: ioc startup files not installed to INSTALL_LOCATION Jeong Han Lee via Tech-talk
