1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: ioc startup files not installed to INSTALL_LOCATION
From: Jeong Han Lee via Tech-talk <[email protected]>
To: Felix Krämer <[email protected]>
Cc: Talk EPICS Tech <[email protected]>
Date: Mon, 14 Dec 2020 20:36:48 -0800
Hi Felix,
The similar stories ended with no community solution, however, please
look at the following threads :
https://epics.anl.gov/tech-talk/2012/msg02173.php
You may realize the better idea while reading these threads. But I
like your first option, which is a simple approach.
HTH,
Han
On Mon, Dec 14, 2020 at 12:53 PM Matt Rippa via Tech-talk
<[email protected]> wrote:
> Hi Felix,
> Some solutions to package applications have been discussed here (in the debian context): https://epics.anl.gov/tech-talk/2018/msg02078.php
> I agree with you, it would be great to have some generic rules in EPICS base supporting both rpm and debian packages. I suspect the differences
> are great enough this becomes very messy.
> -Matt
> On Mon, Dec 14, 2020 at 6:23 AM Felix Krämer via Tech-talk <[email protected]> wrote:
>> Hi all,
>> Currently, I do some contractor work for Gemini for a new Application
>> Development Environment based on RPM.
>> In this context, I am working on one part of it to provide a framework
>> for softIOC installation, everything readily set up with conserver
>> configuration, procServ etc. after installing a respective softIOC RPM.
>> I do this development work based on a makeBaseApp.pl generated softIOC
>> example from the EPICS Application Developer's Guide (
>> https://epics.anl.gov/base/R3-15/6-docs/AppDevGuide/GettingStarted.html#x3-60002.2
>> ). For installing EPICS software using RPM we have to _relocate_
>> installed binaries, scripts etc. This works well, principally, but
>> regarding the example softIOC there do arise a few questions:
>> (1) The startup file under iocBoot (st.cmd) is not installed anywhere.
>> If INSTALL_LOCATION is not redefined, then this is not a problem, but if
>> I want to keep the sources distinct from the product, this seems not to
>> be consequent. I changed the Makefile from
>> TOP = ../..
>> include $(TOP)/configure/CONFIG
>> ARCH = $(EPICS_HOST_ARCH)
>> TARGETS = envPaths
>> include $(TOP)/configure/RULES.ioc
>> to
>> TOP = ../..
>> TARGETS = envPaths
>> SCRIPTS_IOC_Linux += st.cmd
>> to install the st.cmd to the binary install dir, at least. Additionally,
>> I set IOCS_APPL_TOP in CONFIG_SITE to the install location to let
>> envPaths look right. This works so far. Is this the way to go?
>> In this context it might also be an idea to create a new template
>> directory for makeBaseApp.pl and point to it using the -T option. I'd
>> rather use the EPICS original ones, though, to have no adaption work
>> with future versions.
>> (2) Another option I thought about would be to define a User Created
>> File type
>> https://epics.anl.gov/base/R3-15/6-docs/AppDevGuide/BuildFacility.html#x5-1570004.6.35
>> ), e.g. a FILE_TYPE IOCBOOT which would install this st.cmd to a
>> INSTALL_IOCBOOT = $(INSTALL_LOCATION)/iocBoot/.... directory, for
>> example. But same here: it's sort of 'proprietary' to do things like
>> these and such special solutions might be incompatible with future
>> versions of EPICS.
>> Or do I think completely in the wrong direction and there is already a
>> mechanism  in place which to install the startup files to
>> INSTALL_LOCATION which I simply do not see?
>> Any help or ideas as well as confirmation appreciated.
>> Thanks,
>> Felix
ioc startup file installation Felix Krämer via Tech-talk
ioc startup files not installed to INSTALL_LOCATION Felix Krämer via Tech-talk
Re: ioc startup files not installed to INSTALL_LOCATION Matt Rippa via Tech-talk
Prev: Re: Timestamping Confusion Johnson, Andrew N. via Tech-talk
Next: Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: ioc startup files not installed to INSTALL_LOCATION Matt Rippa via Tech-talk
Next: ADPvCam IOC Makefile bug Jörn Dreyer via Tech-talk
