1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: synApps_6_1 build error on windows-x64 with EPICS 7
From: Markus Huber via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 17 Dec 2020 14:17:44 +0100
Dear EPICS community,
I am quite new to EPICS and currently trying to get some synApps_6_1
modules running.
I want to use EPICS for building a SCADA system for an experimental
sectorcoupled microgird.
So far i have built EPICS 7 and tested it successfully with a simple
example application and with CSS (Phoebus).
Now i want to build synApps for using further modules.
When i try to build synApps_6_1 i get the following error after a while
(from line 2359 after 'make rebuild'):
"C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./snc
install
make[3]: Entering directory
'C:/Installationen/synApps_6_1/support/seq-2-2-6/src/snc'
perl -CSD
C:/Installationen/EPICS/base-7.0.4.1/base-R7.0.4.1/bin/windows-x64/makeMakefile.pl
O.windows-x64 ../../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
O.windows-x64 -f ../Makefile TOP=../../.. \
    T_A=windows-x64 install
make[4]: Entering directory
'C:/Installationen/synApps_6_1/support/seq-2-2-6/src/snc/O.windows-x64'
C:/Installationen/synApps_6_1/support/seq-2-2-6/bin/windows-x64/lemon.exe
o=. ../snl.lem
2 parsing conflicts.
perl -CSD
C:/Installationen/EPICS/base-7.0.4.1/base-R7.0.4.1/bin/windows-x64/mkmf.pl
-m snl.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc
-I../../../include/os/WIN32 -I../../../include
-IC:/Installationen/EPICS/base-7.0.4.1/base-R7.0.4.1/include/compiler/msvc
-IC:/Installationen/EPICS/base-7.0.4.1/base-R7.0.4.1/include/os/WIN32
-IC:/Installationen/EPICS/base-7.0.4.1/base-R7.0.4.1/include snl.obj snl.c
re2c.exe -s -b -o lexer.c ../snl.re
process_begin: CreateProcess(NULL, re2c.exe -s -b -o lexer.c ../snl.re,
...) failed.
make (e=2): Das System kann die angegebene Datei nicht finden.
perl -CSD
-m type_check.d -I. -I../O.Common -I. -I. -I..
-I../../../include/compiler/msvc -I../../../include/os/WIN32
-I../../../include
type_check.obj ../type_check.c
perl -CSD
-m builtin.d -I. -I../O.Common -I. -I. -I..
-I../../../include
-IC:/Installationen/EPICS/base-7.0.4.1/base-R7.0.4.1/include builtin.obj
../builtin.c
perl -CSD
-m sym_table.d -I. -I../O.Common -I. -I. -I..
-I../../../include
sym_table.obj ../sym_table.c
perl -CSD
-m gen_tables.d -I. -I../O.Common -I. -I. -I..
-I../../../include
gen_tables.obj ../gen_tables.c
perl -CSD
-m gen_ss_code.d -I. -I../O.Common -I. -I. -I..
-I../../../include
gen_ss_code.obj ../gen_ss_code.c
perl -CSD
-m gen_code.d -I. -I../O.Common -I. -I. -I..
-I../../../include
gen_code.obj ../gen_code.c
perl -CSD
-m analysis.d -I. -I../O.Common -I. -I. -I..
-I../../../include
analysis.obj ../analysis.c
perl -CSD
-m var_types.d -I. -I../O.Common -I. -I. -I..
-I../../../include
var_types.obj ../var_types.c
perl -CSD
-m node.d -I. -I../O.Common -I. -I. -I..
-I../../../include
-IC:/Installationen/EPICS/base-7.0.4.1/base-R7.0.4.1/include node.obj
../node.c
perl -CSD
-m main.d -I. -I../O.Common -I. -I. -I..
-I../../../include
-IC:/Installationen/EPICS/base-7.0.4.1/base-R7.0.4.1/include main.obj
../main.c
...) failed.
[Translation: The System cannot find the specified file.]
"Installing generic include file ../../../include/seqMain.c"
make[4]: *** No rule to make target 'lexer.c', needed by 'lexer.obj'.  Stop.
make[4]: Leaving directory
make[3]: ***
[C:/Installationen/EPICS/base-7.0.4.1/base-R7.0.4.1/configure/RULES_ARCHS:58:
install.windows-x64] Error 2
make[3]: Leaving directory
make[2]: ***
[C:/Installationen/EPICS/base-7.0.4.1/base-R7.0.4.1/configure/RULES_DIRS:85:
snc.install] Error 2
make[2]: Leaving directory
'C:/Installationen/synApps_6_1/support/seq-2-2-6/src'
make[1]: ***
src.install] Error 2
make[1]: Leaving directory 'C:/Installationen/synApps_6_1/support/seq-2-2-6'
make: ***
C:/Installationen/synApps_6_1/support/seq-2-2-6.install] Error 2"
The specification of my "building-environment":
* Windows 10, 64-bit, ProcessorArchitecture: AMD64
* x64 Native Tools Command Prompt for VS 2019
* make --version outputs: GNU Make 4.3 Built for Windows32
* perl --version outputs: This is perl 5, version 32, subversion 0
(v5.32.0) built for MSWin32-x64-multi-thread
I followed the instructions in
synApps_6_1/support/documentation/synApps.html. Point 2.4 in this
documentation says: "synApps is tested with the architectures
linux-x86_64, win32-x86, and win64-x86". Does it also run with windows-x64?
In support\configure\RELEASE SUPPORT and EPICS_BASE are set as follows:
* SUPPORT=C:/Installationen/synApps_6_1/support
* EPICS_BASE=C:/Installationen/EPICS/base-7.0.4.1/base-R7.0.4.1
Do i need to install/build something else before? Except from EPICS Base
7 i have built nothing else from the EPICS framework.
A search for "lexer.c" in the Windows-explorer is not successful.
When i comment seq-2-2-6 in support/configure/RELEASE, i get another Error:
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE
-D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3        -MD
-DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I..
-I../../../include
-IC:/Installationen/synApps_6_1/support/ipac-2-15/include
-IC:/Installationen/synApps_6_1/support/seq-2-2-6/include
-IC:/Installationen/EPICS/base-7.0.4.1/base-R7.0.4.1/include -c
../ipEchoServer2.c
ipEchoServer2.c
make[4]: *** No rule to make target 'ipSNCServer.obj', needed by
'testIPServerSupport.dll'.  Stop.
'C:/Installationen/synApps_6_1/support/asyn-R4-36/testIPServerApp/src/O.windows-x64'
make[3]: ***
'C:/Installationen/synApps_6_1/support/asyn-R4-36/testIPServerApp/src'
make[2]: ***
'C:/Installationen/synApps_6_1/support/asyn-R4-36/testIPServerApp'
make[1]: ***
testIPServerApp.install] Error 2
'C:/Installationen/synApps_6_1/support/asyn-R4-36'
make: ***
C:/Installationen/synApps_6_1/support/asyn-R4-36.install] Error 2"
After that, i commented ipac-2-15 in support/configure/RELEASE, did
"make release", did "make rebuild": This results in a similar error:
make[3]: ***
install.windows-x64] Error 2"
Since i need asyn, i cannot comment it in support/configure/RELEASE.
Do you have any ideas, what i could have done wrong? Should I use EPICS
Base 3.15?
Thank you very much and kind regards,
Markus
Markus Huber
MSc Student, Technical University Munich, Germany
[email protected], [email protected]
Re: synApps_6_1 build error on windows-x64 with EPICS 7 Johnson, Andrew N. via Tech-talk
Prev: Intended use of NTMultiChannel Paduan Donadio, Marcio via Tech-talk
Next: Re: Intended use of NTMultiChannel Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Intended use of NTMultiChannel Michael Davidsaver via Tech-talk
Next: Re: synApps_6_1 build error on windows-x64 with EPICS 7 Johnson, Andrew N. via Tech-talk
