1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Intended use of NTMultiChannel
From: "Paduan Donadio, Marcio via Tech-talk" <[email protected]>
Date: Thu, 17 Dec 2020 05:11:31 +0000
I have a NTMultiChannel created using the C++ API. I pvput to channelName passing a valid PV name. I placed a printf inside the process() method just to check if the record is processing and I can confirm it does.
When I pvget I expected to see the other fields of the record populated with values from the PV in channelName. Is it intended that inside process() I write the commands to bring the data for each channel and write to the fields of the NTMultiChannel? Is there a default “record support” that has it already implemented and I can use?
Some data:
Epics base 7.0.3
$ pvget GMDTest:NTScalar
GMDTest:NTScalar 0
$ pvput GMDTest:NTMultiChannel 'channelName=["GMDTest:NTScalar"]'
Old : epics:nt/NTMultiChannel:1.0
    any[] value
    string[] channelName []
    int[] severity []
    int[] status []
    string[] message []
    boolean[] isConnected []
New : epics:nt/NTMultiChannel:1.0
    any[] value
    string[] channelName ["GMDTest:NTScalar"]
    int[] severity []
    int[] status []
    string[] message []
$ pvget GMDTest:NTMultiChannel
GMDTest:NTMultiChannel epics:nt/NTMultiChannel:1.0
    any[] value
    int[] severity []
    int[] status []
    string[] message []
Re: Intended use of NTMultiChannel Michael Davidsaver via Tech-talk
Prev: RE: [EXTERNAL] RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Next: synApps_6_1 build error on windows-x64 with EPICS 7 Markus Huber via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: WITec alpha300R VIS Heinz Junkes via Tech-talk
Next: Re: Intended use of NTMultiChannel Michael Davidsaver via Tech-talk
