Subject: Re: Intended use of NTMultiChannel
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Paduan Donadio, Marcio" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 17 Dec 2020 07:27:01 -0800
On 12/16/20 9:11 PM, Paduan Donadio, Marcio via Tech-talk wrote:
> I have a NTMultiChannel created using the C++ API.
Which c++ API specifically?
> I pvput to channelName passing a valid PV name. I placed a printf inside the process() method just to check if the record is processing and I can confirm it does.
> When I pvget I expected to see the other fields of the record populated with values from the PV in channelName. Is it intended that inside process() I write the commands to bring the data for each channel and write to the fields of the NTMultiChannel? Is there a default “record support” that has it already implemented and I can use?
If you are referring to pvDatabaseCPP, then probably not.  It is more analogous to PCAS.
You might look at the PVA link support as a way of having an IOC act as a PVA client.
https://epics-base.github.io/pva2pva/qsrv_page.html#qsrv_link
> Some data:
> Epics base 7.0.3
> $ pvget GMDTest:NTScalar
> GMDTest:NTScalar 0
> $ pvput GMDTest:NTMultiChannel 'channelName=["GMDTest:NTScalar"]'
> Old : epics:nt/NTMultiChannel:1.0
>     any[] value
>     string[] channelName []
>     int[] severity []
>     int[] status []
>     string[] message []
>     boolean[] isConnected []
> New : epics:nt/NTMultiChannel:1.0
>     any[] value
>     string[] channelName ["GMDTest:NTScalar"]
>     int[] severity []
>     int[] status []
>     string[] message []
> $ pvget GMDTest:NTMultiChannel
> GMDTest:NTMultiChannel epics:nt/NTMultiChannel:1.0
>     any[] value
>     int[] severity []
>     int[] status []
>     string[] message []
Re: Intended use of NTMultiChannel Paduan Donadio, Marcio via Tech-talk
Prev: synApps_6_1 build error on windows-x64 with EPICS 7 Markus Huber via Tech-talk
Next: Re: synApps_6_1 build error on windows-x64 with EPICS 7 Johnson, Andrew N. via Tech-talk
Prev: Intended use of NTMultiChannel Paduan Donadio, Marcio via Tech-talk
Next: Re: Intended use of NTMultiChannel Paduan Donadio, Marcio via Tech-talk
