1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Intended use of NTMultiChannel
From: "Paduan Donadio, Marcio via Tech-talk" <[email protected]>
Date: Fri, 18 Dec 2020 05:15:04 +0000
Hi, Michael.
Thank you for the tip about using PVA link support. I’ve created a group with some PVs and the result looks like what I was trying to achieve with NTMultiChannel.
Two questions:
1 – Is there a way to call a function every time a group processes? I’d like to create a device-support-like thing to read the fields and values of each channel and calculate things.
2 – Is there a way to pvget individual fields of a group? Something like pvget grp:name.X.
Thank you,
Márcio Paduan Donadio
Control Systems Engineer - SLAC
Date: Thursday, December 17, 2020 at 7:28 AM
To: Paduan Donadio, Marcio <[email protected]>, [email protected] <[email protected]>
On 12/16/20 9:11 PM, Paduan Donadio, Marcio via Tech-talk wrote:
> I have a NTMultiChannel created using the C++ API.
Which c++ API specifically?
> I pvput to channelName passing a valid PV name. I placed a printf inside the process() method just to check if the record is processing and I can confirm it does.
> When I pvget I expected to see the other fields of the record populated with values from the PV in channelName. Is it intended that inside process() I write the commands to bring the data for each channel and write to the fields of the NTMultiChannel? Is there a default “record support” that has it already implemented and I can use?
If you are referring to pvDatabaseCPP, then probably not.  It is more analogous to PCAS.
You might look at the PVA link support as a way of having an IOC act as a PVA client.
https://epics-base.github.io/pva2pva/qsrv_page.html#qsrv_link
> Some data:
> Epics base 7.0.3
> $ pvget GMDTest:NTScalar
> GMDTest:NTScalar 0
> $ pvput GMDTest:NTMultiChannel 'channelName=["GMDTest:NTScalar"]'
> Old : epics:nt/NTMultiChannel:1.0
>     any[] value
>     string[] channelName []
>     int[] severity []
>     int[] status []
>     string[] message []
>     boolean[] isConnected []
> New : epics:nt/NTMultiChannel:1.0
>     any[] value
>     string[] channelName ["GMDTest:NTScalar"]
>     int[] severity []
>     int[] status []
>     string[] message []
> $ pvget GMDTest:NTMultiChannel
> GMDTest:NTMultiChannel epics:nt/NTMultiChannel:1.0
>     any[] value
>     int[] severity []
>     int[] status []
>     string[] message []
Re: Intended use of NTMultiChannel Michael Davidsaver via Tech-talk
Intended use of NTMultiChannel Paduan Donadio, Marcio via Tech-talk
Prev: Re: Splitting a string in a protocol file Michael Davidsaver via Tech-talk
Next: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Intended use of NTMultiChannel Michael Davidsaver via Tech-talk
Next: Re: Intended use of NTMultiChannel Michael Davidsaver via Tech-talk
