Subject: RE: changing unit string to scale factor
To: 'Randall Cayford' <[email protected]>
Date: Mon, 25 Jan 2021 20:27:06 +0000
Look at the scalcout record:
http://htmlpreview.github.io/?https://github.com/epics-modules/calc/blob/master/documentation/sCalcoutRecord.html
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Randall Cayford via Tech-talk
Sent: Monday, January 25, 2021 2:16 PM
To: Engbretson, Mark S. via Tech-talk <[email protected]>
Subject: changing unit string to scale factor
I have a device which returns a value and a string indicating the units of the value.  I’ll get inputs like 0.3nA or 3.4mA, etc.  Since I want to report the value in a consistent unit, I want to convert the unit string to a scale factor (nA=1, uA=1000, mA=10000) and then use a calc record to scale the value.   CALC records seem to only take numbers as input and I don’t see any other appropriate record type.
In programming I would use a case statement or if-elseif constructs.  How do I do this with EPICS record processing?
Randall
LBNL
changing unit string to scale factor Randall Cayford via Tech-talk
Prev: Re: Channel connection performance Michael Davidsaver via Tech-talk
Next: RE: changing unit string to scale factor Mark Rivers via Tech-talk
Prev: changing unit string to scale factor Randall Cayford via Tech-talk
