Subject: changing unit string to scale factor
From: Randall Cayford via Tech-talk <[email protected]>
To: "Engbretson, Mark S. via Tech-talk" <[email protected]>
Date: Mon, 25 Jan 2021 12:16:24 -0800
I have a device which returns a value and a string indicating the units of the value.  I’ll get inputs like 0.3nA or 3.4mA, etc.  Since I want to report the value in a consistent unit, I want to convert the unit string to a scale factor (nA=1, uA=1000, mA=10000) and then use a calc record to scale the value.   CALC records seem to only take numbers as input and I don’t see any other appropriate record type.
In programming I would use a case statement or if-elseif constructs.  How do I do this with EPICS record processing?
Randall
LBNL
RE: changing unit string to scale factor Mark Rivers via Tech-talk
Re: changing unit string to scale factor Zimoch Dirk (PSI) via Tech-talk
Prev: Altering timestamp of softIOC PV Reimer, Paul E. via Tech-talk
Next: Re: Channel connection performance Michael Davidsaver via Tech-talk
Prev: Re: Altering timestamp of softIOC PV Johnson, Andrew N. via Tech-talk
Next: RE: changing unit string to scale factor Mark Rivers via Tech-talk
