Subject: Re: Altering timestamp of softIOC PV
From: "Reimer, Paul E. via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Date: Tue, 26 Jan 2021 00:59:40 +0000
I have several work a rounds.  Right now, we store a timestamp PV as the acquisition time and then the data in additional PVs.  The correct way is to have the DAQ system call the ca_put immediately (the data is coming in at a 5 Hz level). There are others which collaborators have suggested as well. It just seemed unnecessarily complicated and un-natural given that there exists a location in the record for the time already.
It is of course possible to write some C code for the IOC that will let you do that, but the fact that it isn’t easy is an indication to me that there may a better way to do what you’re looking for.
I think that this really answers my question--it is not a trivial task.  My hope was that I had missed something in the manual or mailing lists that would tell me how to do this; although, the more I think about possible implications of essentially "changing history" it is probably not a good idea to allow.
Paul
On 1/25/21 17:09, Johnson, Andrew N. wrote:
Hi Paul,
On Jan 25, 2021, at 4:41 PM, Reimer, Paul E. via Tech-talk <[email protected]> wrote:
The "acquisition time" is a trigger generated elsewhere and served by equipment that, at this time, can't talk directly to EPICS.  The best solution is to have the acquisition system talk directly with EPICS--I argued for this--but that is not what I have. The data is essentially buffered (with and acquisition timestamp) and then handed off to a system that talks with EPICS.
Are there any other protocols or APIs that an IOC might be able to use to communicate with the system, and what kinds of data sizes and rates are involved in the data transfers?
EPICS systems don’t generally use Channel Access clients as agents for acquiring data, and as a result we don’t have an easy way to put an EPICS timestamp into a Channel Access PV. It is of course possible to write some C code for the IOC that will let you do that, but the fact that it isn’t easy is an indication to me that there may a better way to do what you’re looking for.
If you could describe the larger problem to the community (i.e. to this list) we might be able to recommend alternatives that could turn out to be faster and easier – no promises, but it’s worth a try.
- Andrew
On 1/25/21 16:34, Arnold, Ned D. wrote:
> I would like the timestamp field for that PV to reflect the acquisition time rather
than the time that the ca_put(DBR_LONG, stchid, &iParVal) routine is
called.
Is the "acquisition time" a user defined time, an event within the IOC, or an external trigger generated from somewhere else?
  Ned
From: Tech-talk <[email protected]> on behalf of Reimer, Paul E. via Tech-talk<[email protected]>
Sent: Monday, January 25, 2021 02:14 PM
To: [email protected] <[email protected]>
Subject: Altering timestamp of softIOC PV
Hello,
Is it possible to alter the timestamp field of a PV? Specifically, I
have a situation in which data is recorded by a computer, but might not
be put into EPICS immediately (few sec delay is possible). I would like
called.  I note that the time field is of type "NOACCESS" in the manual.
Paul
If you receive this e-mail after hours, during a weekend, or on a holiday,
please enjoy your time off and respond during your working hours.
Paul E Reimer               +1-630-252-4037 (Office)
Bldg 203, Physics Division  +1-630-252-3903 (fax)
Argonne National Laboratory +1-630-344-9207 (mobile)
9700 S Cass Ave             [email protected]
Lemont, IL  60439 USA.      he/his/him
Complexity comes for free, simplicity you have to work for.
Re: Altering timestamp of softIOC PV Johnson, Andrew N. via Tech-talk
Altering timestamp of softIOC PV Reimer, Paul E. via Tech-talk
Re: Altering timestamp of softIOC PV Arnold, Ned D. via Tech-talk
Re: Altering timestamp of softIOC PV Reimer, Paul E. via Tech-talk
Prev: EPICS Archiver routing issue Manoussakis, Adamandios via Tech-talk
Next: Re: Altering timestamp of softIOC PV Johnson, Andrew N. via Tech-talk
Prev: Re: Altering timestamp of softIOC PV Johnson, Andrew N. via Tech-talk
