Subject: EPICS Archiver routing issue
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Tue, 26 Jan 2021 00:55:32 +0000
Hello All,
I think I am having problems with routing with the epics archiver.  When I have the archiver on a LAN and is on the same subnet as the IOCs being archived it seems to work fine but when I have archiver on a different subnet it doesn’t seem to want to archive those PVs anymore. For example
Same Subnet, CS Studio Picks up PVs, caget works, archiver works
192.168.10.20 Epics Archiver Computer
192.168.10.21 IOC running
Different Subnet, CS Studio picks up PVs, caget works, Archiver will not archive PVs
192.168.11.21 IOC running
I have both the epics variables set in my env variables, in archappl.conf (archiver file), in settings.ini (cs studio file).  It seems odd that caget, cs studio work fine but the archiver is having an issue seeing the IOC that is on the other subnet.  Is there another environment variable I am missing that needs to be set when services are on different subnets like this?  I checked firewalls/ports/traffic it seems like the same requests are being made by cs studio/caget as the archiver but the archiver ones don’t seem to go anywhere (just keep trying to retransmit).
EPICS_CA_ADDR_LIST=192.168.11.21
EPICS_CA_AUTO_ADDR_LIST=YES
RE: EPICS Archiver routing issue Abdalla Ahmad via Tech-talk
Prev: Re: changing unit string to scale factor Jeong Han Lee via Tech-talk
Next: Re: Altering timestamp of softIOC PV Reimer, Paul E. via Tech-talk
Prev: Re: Can I open a CSS Phoebus layout from the command line Kasemir, Kay via Tech-talk
Next: RE: EPICS Archiver routing issue Abdalla Ahmad via Tech-talk
