Subject: Re: Can I open a CSS Phoebus layout from the command line
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Phillip A. Sorensen" <[email protected]>, "Kasemir, Kay" <[email protected]>
Date: Tue, 26 Jan 2021 13:28:57 +0000
>> I can open it from the Window->Open Layout menu, but I was wondering if
>> there is a way to open a layout from a command line parameter.  I would
>> like to create a wrapper that starts phoebus with the alarm layout.
>Right now there is no "-open_layout" type command line option, but you can do the following:
There will soon be this command line option:
-layout /path/to/Example.memento        -  Start with the specified saved layout instead of the default 'memento'
See https://github.com/ControlSystemStudio/phoebus/pull/1747
-Kay
Can I open a CSS Phoebus layout from the command line Phillip A. Sorensen via Tech-talk
Re: Can I open a CSS Phoebus layout from the command line Kasemir, Kay via Tech-talk
Prev: Re: EPICS Module mrfioc2 Hu, Yong via Tech-talk
Next: RE: EPICS Module mrfioc2 Abdalla Ahmad via Tech-talk
Prev: Re: Can I open a CSS Phoebus layout from the command line Kasemir, Kay via Tech-talk
Next: EPICS Archiver routing issue Manoussakis, Adamandios via Tech-talk
