Subject: Re: EPICS Module mrfioc2
To: Abdalla Ahmad <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Jan 2021 13:21:40 +0000
Hi Abdalla, I think this is what you are looking for: https://github.com/KIT-IBPT/epics-mrf
Good luck!
Yong
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: Abdalla Ahmad <[email protected]>
Date: Tuesday, January 26, 2021 at 5:42 AM
Subject: EPICS Module mrfioc2
Hi
I came across this module https://github.com/epics-modules/mrfioc2 when searching for a driver for MRM-based timing system hardware. Looking at the source code it does not seem to work with Ethernet connected hardware, only VME. Our timing system hardware is inserted into a VME chassis but connected to the control system via the board’s Ethernet interface. Can this driver be configured to connect to Ethernet-connected hardware?
Thanks.
Abdalla.
RE: EPICS Module mrfioc2 Abdalla Ahmad via Tech-talk
Prev: EPICS Module mrfioc2 Abdalla Ahmad via Tech-talk
Next: Re: Can I open a CSS Phoebus layout from the command line Kasemir, Kay via Tech-talk
Next: RE: EPICS Module mrfioc2 Abdalla Ahmad via Tech-talk
