Subject: RE: EPICS Module mrfioc2
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: "Hu, Yong" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Jan 2021 13:30:36 +0000
Thanks Yong this should be helpful. Does it support specific firmware versions? We were using a custom driver but we found out that it was made for the older firmware E401, the spare parts we have we found out they are using the MRM (Modular register map) firmware (6 or 7 I think), so I wonder if the driver is handling firmware versions differences.
Best Regards,
Abdalla.
Sent: Tuesday, January 26, 2021 3:22 PM
To: Abdalla Ahmad <[email protected]>; [email protected]
Subject: Re: EPICS Module mrfioc2
Hi Abdalla, I think this is what you are looking for: https://github.com/KIT-IBPT/epics-mrf
Good luck!
Yong
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: Abdalla Ahmad <[email protected]>
Date: Tuesday, January 26, 2021 at 5:42 AM
Subject: EPICS Module mrfioc2
Hi
I came across this module https://github.com/epics-modules/mrfioc2 when searching for a driver for MRM-based timing system hardware. Looking at the source code it does not seem to work with Ethernet connected hardware, only VME. Our timing system hardware is inserted into a VME chassis but connected to the control system via the board’s Ethernet interface. Can this driver be configured to connect to Ethernet-connected hardware?
Thanks.
Abdalla.
Re: EPICS Module mrfioc2 Hu, Yong via Tech-talk
EPICS Module mrfioc2 Abdalla Ahmad via Tech-talk
Prev: Re: Can I open a CSS Phoebus layout from the command line Kasemir, Kay via Tech-talk
Next: Re: Python cothread errors Hu, Yong via Tech-talk
Prev: Re: EPICS Module mrfioc2 Hu, Yong via Tech-talk
Next: Re: EPICS Module mrfioc2 Hu, Yong via Tech-talk
