Subject: Re: EPICS Archiver routing issue
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 26 Jan 2021 10:19:57 +0100
Reminder...
The Channel Access command line tools are binary executables built from C sources.
CS-Studio and the Archive Appliance are Java applications.
As such, they are using different Channel Access libraries.
While C/C++ binaries are often configured through environment variables, Java applications are often configured through their Preferences settings.
The Java Channel Access libraries have been trying to also take environment variable settings into account. That still produces surprising results in some cases, especially when both environment variables and Preferences are being set.
For the environment variables, it is correct that
AUTO_ADDR_LIST=YES means: automatically prefill the address list with the broadcast addresses of all network interfaces found.
ADDR_LIST specifies addresses that are added to the address list (that can be broadcast addresses).
Cheers,
~Ralph
RE: EPICS Archiver routing issue Manoussakis, Adamandios via Tech-talk
RE: EPICS Archiver routing issue Abdalla Ahmad via Tech-talk
Prev: RE: EPICS Archiver routing issue Manoussakis, Adamandios via Tech-talk
Next: Re: changing unit string to scale factor Zimoch Dirk (PSI) via Tech-talk
Next: RE: EPICS Archiver routing issue Manoussakis, Adamandios via Tech-talk
