Subject: combining long strings
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
Date: Mon, 1 Feb 2021 10:42:39 +0000
Hello EPICS-community,
I’m trying to find a solution for the following calculation:
record(scalcout,"$(exp):FilePath") {
  field(INAA,"$(exp):PathMenu.VAL CP")
  field(INBB,"$(exp):DateMenu.VAL CP")
  field(INCC,"$(exp):SampleMenu.VAL CP")
  field(INDD,"$(exp):OrientationMenu.VAL CP")
  field(INEE,"$(exp):EnergyMenu.VAL CP")
  field(INFF,"$(cam):$(format)1:FileNumber CP")
  field(CALC,"AA+BB+CC+DD+EE+FF")
  field(OUT,"$(cam):$(format)1:FilePath")
INAA to INFF are mbbo records that I want to use as dropdown-menus. Each time a dropdown-menu is changed by the user, the scalcout record recalculates the FilePath and puts the new path-string to the areaDetector FilePath record, which is a waveform. This would work fine, if there wasn’t the 40 character limitation for the scalcout-record, so the OUT field is cut. Each of the input fields is smaller then 40 character but combined (the actual path-string) is longer. Can anyone give me an example how to solve this, if possible? I searched the tech-talk but with no luck…
Regards
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8104-5736 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]
Re: combining long strings Lang, Keenan C. via Tech-talk
Prev: Re: EPICS Codeathon: March 8 to March 12 Ben Franksen via Tech-talk
Next: Re: Areadetector driver for AVT-Marlin Firewire Camera on Windows Malu, Sandeep Kumar (-, RAL, CLF) via Tech-talk
Prev: Re: Re: Re: Re: Re: RE: Re: Re: modbus write registers error to Pilz PLC Mark Rivers via Tech-talk
Next: Re: combining long strings Lang, Keenan C. via Tech-talk
