Subject: Re: combining long strings
From: "Lang, Keenan C. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Sintschuk, Michael" <[email protected]>
Date: Tue, 2 Feb 2021 03:40:01 +0000
Hello Michael,
I believe that you could theoretically solve this with separate waveform records for each of the input values, then use an acalcout record to concatenate the arrays together.
Otherwise, I would also like to put forward the luascript record (https://github.com/epics-modules/lua). It works very similarly to the calc style records just with a full programming language behind it. I had to put in a commit because I wasn't previously pulling in enum data, but if you grab the master branch you could do this:
record(luascript,"$(exp):FilePath") {
  field(INAA,"$(exp):PathMenu.VAL CP")
  field(INBB,"$(exp):DateMenu.VAL CP")
  field(INCC,"$(exp):SampleMenu.VAL CP")
  field(INDD,"$(exp):OrientationMenu.VAL CP")
  field(INEE,"$(exp):EnergyMenu.VAL CP")
  field(INFF,"$(cam):$(format)1:FileNumber CP")
  field(CODE,"return table.pack(string.byte(AA..BB..CC..DD..EE..FF, 1, -1))")
  field(OUT,"$(cam):$(format)1:FilePath PP")
The CODE field there concatenates the strings, turns the resulting string into a set of bytes, then puts those bytes together into an array which the record can write out to a waveform.
Keenan
From: Tech-talk <[email protected]> on behalf of Sintschuk, Michael via Tech-talk <[email protected]>
Sent: Monday, February 1, 2021 4:42 AM
To: [email protected] <[email protected]>
Subject: combining long strings
Hello EPICS-community,
I’m trying to find a solution for the following calculation:
record(scalcout,"$(exp):FilePath") {
  field(CALC,"AA+BB+CC+DD+EE+FF")
  field(OUT,"$(cam):$(format)1:FilePath")
INAA to INFF are mbbo records that I want to use as dropdown-menus. Each time a dropdown-menu is changed by the user, the scalcout record recalculates the FilePath and puts the new path-string to the areaDetector FilePath record, which is a waveform. This would work fine, if there wasn’t the 40 character limitation for the scalcout-record, so the OUT field is cut. Each of the input fields is smaller then 40 character but combined (the actual path-string) is longer. Can anyone give me an example how to solve this, if possible? I searched the tech-talk but with no luck…
Regards
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8104-5736 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]
AW: combining long strings Sintschuk, Michael via Tech-talk
Prev: US ITER seeking Lead Software Engineer Vetter, Kurt G. via Tech-talk
Next: device support for Edwards active gauge controller Heinz Junkes via Tech-talk
Prev: combining long strings Sintschuk, Michael via Tech-talk
Next: AW: combining long strings Sintschuk, Michael via Tech-talk
