Subject: AW: combining long strings
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
To: "Lang, Keenan C." <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 3 Feb 2021 14:05:49 +0000
Hi Keenan,
I like the luascript script solution. But unfortunately it won’t work for me. The record is always in SEVR: invalid mode and there is no input to the AA, BB … fields:
epics> dbpr Topo:FilePath 10
A: 0                AA:                 AADN:               ACKS: NO_ALARM
ACKT: YES           ADSC:               ASG:                ASIZ: 0
ASP: (nil)          ATYP: Int           AVAL: (nil)         B: 0
BB:                 BBDN:               BDSC:               BKPT: 00
C: 0                CALL: 0x88d4e0      CC:                 CCDN:
CDSC:
CODE: return table.pack(string.byte(AA..BB..CC..DD..EE..FF, 1, -1))
D: 0                DD:                 DDDN:               DDSC:
DESC:               DISA: 0             DISP: 0             DISS: NO_ALARM
DISV: 1             DPVT: (nil)         DSET: 0x7f8e4c1d9f00
DTYP: Soft Channel  E: 0                EDSC:               EE:
EEDN:               ERR: error in error handling            EVNT:
F: 0                FDSC:               FF:                 FFDN:
FLNK:CONSTANT 0     FRLD: 0             G: 0                GDSC:
GG:                 GGDN:               H: 0                HDSC:
HH:                 HHDN:               I: 0                IAAV: Local PV
IBBV: Local PV      ICCV: Local PV      IDDV: Local PV      IDSC:
IEEV: Local PV      IFFV: Ext PV OK     IGGV: Constant      IHHV: Constant
II:                 IIDN:               IIIV: Constant      IJJV: Constant
INAA:CA_LINK Topo:PathMenu.VAL CP NMS   INAV: Constant
INBB:CA_LINK Topo:DateMenu.VAL CP NMS   INBV: Constant
INCC:CA_LINK Topo:SampleMenu.VAL CP NMS INCV: Constant
INDD:CA_LINK Topo:OrientationMenu.VAL CP NMS                INDV: Constant
INEE:CA_LINK Topo:EnergyMenu.VAL CP NMS INEV: Constant
INFF:CA_LINK PCO4000:TIFF1:FileNumber CP NMS                INFV: Constant
INGG:CONSTANT       INGV: Constant      INHH:CONSTANT       INHV: Constant
INII:CONSTANT       INIV: Constant      INJJ:CONSTANT       INJV: Constant
INPA:CONSTANT       INPB:CONSTANT       INPC:CONSTANT       INPD:CONSTANT
INPE:CONSTANT       INPF:CONSTANT       INPG:CONSTANT       INPH:CONSTANT
INPI:CONSTANT       INPJ:CONSTANT       J: 0                JDSC:
JJ:                 JJDN:               LCNT: 18            LSET: 0x88c750
MDEL: 0
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
MLOK: 20 d4 88 00 00 00 00 00           NAME: Topo:FilePath NSEV: INVALID
NSTA: LINK          OOPT: Every Time
OUT:CA_LINK PCO4000:TIFF1:FilePath PP NMS                   OUTV: Constant
PA: 0               PAA: 0x88d5c0       PACT: 1             PASZ: 0
PATP: Int           PAVL: (nil)         PB: 0               PBB: 0x88d5f0
PC: 0               PCC: 0x88d620       PCODE: 0x88d450     PD: 0
PDD: 0x88d650       PE: 0               PEE: 0x88d680       PF: 0
PFF: 0x88d6b0       PG: 0               PGG: 0x88d6e0       PH: 0
PHAS: 0             PHH: 0x88d710       PI: 0               PII: 0x88d740
PINI: NO            PJ: 0               PJJ: 0x88d770       PPN: (nil)
PPNR: (nil)         PREC: 0             PRIO: LOW           PROC: 0
PSVL:               PUTF: 0             PVAL: 0             RDES: 0x80c5f0
RELO: Every New File                    RPRO: 0             RPVT: 0x88d570
RSET: 0x7f8e4c1d9e40                    SCAN: Passive       SDIS:CONSTANT
SEVR: INVALID       SPVT: (nil)         STAT: UDF           STATE: 0x88d7a8
SVAL:               SYNC: Sync          TIME: <undefined>   TPRO: 0
TSE: 0              TSEL:CONSTANT       UDF: 1              UDFS: INVALID
VAL: 0              WAIT: NoWait
epics>
Did I missed something with the record settings?
Von: Lang, Keenan C. <[email protected]>
Gesendet: Dienstag, 2. Februar 2021 04:40
An: [email protected]; Sintschuk, Michael <[email protected]>
Betreff: Re: combining long strings
Hello Michael,
I believe that you could theoretically solve this with separate waveform records for each of the input values, then use an acalcout record to concatenate the arrays together.
Otherwise, I would also like to put forward the luascript record (https://github.com/epics-modules/lua). It works very similarly to the calc style records just with a full programming language behind it. I had to put in a commit because I wasn't previously pulling in enum data, but if you grab the master branch you could do this:
record(luascript,"$(exp):FilePath") {
  field(INAA,"$(exp):PathMenu.VAL CP")
  field(INBB,"$(exp):DateMenu.VAL CP")
  field(INCC,"$(exp):SampleMenu.VAL CP")
  field(INDD,"$(exp):OrientationMenu.VAL CP")
  field(INEE,"$(exp):EnergyMenu.VAL CP")
  field(INFF,"$(cam):$(format)1:FileNumber CP")
  field(CODE,"return table.pack(string.byte(AA..BB..CC..DD..EE..FF, 1, -1))")
  field(OUT,"$(cam):$(format)1:FilePath PP")
The CODE field there concatenates the strings, turns the resulting string into a set of bytes, then puts those bytes together into an array which the record can write out to a waveform.
Keenan
From: Tech-talk <[email protected]> on behalf of Sintschuk, Michael via Tech-talk <[email protected]>
Sent: Monday, February 1, 2021 4:42 AM
To: [email protected] <[email protected]>
Subject: combining long strings
Hello EPICS-community,
I’m trying to find a solution for the following calculation:
record(scalcout,"$(exp):FilePath") {
  field(CALC,"AA+BB+CC+DD+EE+FF")
  field(OUT,"$(cam):$(format)1:FilePath")
INAA to INFF are mbbo records that I want to use as dropdown-menus. Each time a dropdown-menu is changed by the user, the scalcout record recalculates the FilePath and puts the new path-string to the areaDetector FilePath record, which is a waveform. This would work fine, if there wasn’t the 40 character limitation for the scalcout-record, so the OUT field is cut. Each of the input fields is smaller then 40 character but combined (the actual path-string) is longer. Can anyone give me an example how to solve this, if possible? I searched the tech-talk but with no luck…
Regards
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8104-5736 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]
Re: combining long strings Johnson, Andrew N. via Tech-talk
combining long strings Sintschuk, Michael via Tech-talk
Re: combining long strings Lang, Keenan C. via Tech-talk
Prev: RE: Questions about Bruker QM100 detector Abdalla Ahmad via Tech-talk
Next: Phoebus Strip tool and Databrowser Only Show Latest Point Smith, William via Tech-talk
Prev: Re: combining long strings Lang, Keenan C. via Tech-talk
Next: Re: combining long strings Johnson, Andrew N. via Tech-talk
