Subject: Re: setcap and nosuid
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Siddons, David" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 2 Feb 2021 12:04:33 -0800
On 2/2/21 11:42 AM, Siddons, David wrote:
> At least I still have the root fallback 😉 But I'll try the gpio driver approach.
> Do you have any feeling about the relative speed of mmap and ioctl?
mmap() will be as fast as program I/O can be.  However, it requires dealing with
the potential gotchas of access width, alignment, ordering, and optimizer magic
in a user space program.  It has the benefit though of not needing to manages
a whole bunch of ioctl() flags.
My devlib2 module provides a set of macros for portable MMIO operations in userspace.
These are analogous (and hopefully equivalent) to the Linux kernel ioread*/iowrite*().
http://epics.sourceforge.net/devlib2/group__mmio.html
If you're truly looking for speed, then move straight along to DMA engines.
Program I/O will not come close to the theoretical speeds of modern hardware.
Of course DMA engines come with a long list of complications, and a zoo of
different features sets.
> Pete.
> *From:* Michael Davidsaver <[email protected]>
> *Sent:* Tuesday, February 2, 2021 2:39 PM
> *To:* Siddons, David <[email protected]>
> *Cc:* EPICS Tech-Talk <[email protected]>
> *Subject:* Re: setcap and nosuid
> On 2/2/21 10:49 AM, Siddons, David wrote:
>> Well, everything works fine when running as root.
> Ah, this is an important data point.  This brings us around to Linux capabilities.
> It might be sufficient if you were able to set a file capability of CAP_SYS_RAWIO.
>> I am just being encouraged to stop doing that 🙂
> Sage advice.  And I should probably stop encouraging you to keep trying with /dev/mem then :)
>> Pete.
>> *Sent:* Tuesday, February 2, 2021 1:48 PM
>> On 2/2/21 10:09 AM, Siddons, David wrote:
>>> Hi Michael,
>>>    Setting 0666 doesn't help.
>> Maybe your kernel doesn't have /dev/mem enabled either?
>>> $ grep DEVMEM /boot/config-5.9.0-0.bpo.5-amd64
>>> CONFIG_DEVMEM=y
>>> CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
>>> CONFIG_STRICT_DEVMEM=y
>>> CONFIG_IO_STRICT_DEVMEM=y
>>> THanks for the link. I missed that before. It looks like the right way to go. I'll dig into it.
>>> Pete.
>>> *Sent:* Tuesday, February 2, 2021 12:13 PM
>>> On 2/2/21 8:57 AM, Siddons, David wrote:
>>>> Hi David,
>>>> Yes, I saw that. Changing it doesn't seem to help:
>>>> sudo chmod g+w /dev/mem
>>>> ls -l /dev/mem
>>>> crw-rw---- 1 root kmem 1, 1 Feb  1 21:05 /dev/mem
>>>> ./regrw R 1   ( a program which maps the FPGA registers to userspace)
>>>> Reading Register 1
>>>> Can't open /dev/mem
>>> Have you tried chmod 0666 to make sure this is really a permission problem?
>>> The "Can't open" could also print 'errno'.
>>> Also, I feel obligated to repeat myself in recommending against using
>>> /dev/mem in any kind of long term solution.  There are safer ways
>>> to grant access to specific MMIO ranges.
>>> https://epics.anl.gov/tech-talk/2020/msg02201.php <https://epics.anl.gov/tech-talk/2020/msg02201.php> <https://epics.anl.gov/tech-talk/2020/msg02201.php <https://epics.anl.gov/tech-talk/2020/msg02201.php>> <https://epics.anl.gov/tech-talk/2020/msg02201.php <https://epics.anl.gov/tech-talk/2020/msg02201.php <https://epics.anl.gov/tech-talk/2020/msg02201.php>>>
setcap and nosuid Michael Davidsaver via Tech-talk
Re: setcap and nosuid Siddons, David via Tech-talk
Re: setcap and nosuid Michael Davidsaver via Tech-talk
Prev: Re: setcap and nosuid Siddons, David via Tech-talk
Next: motor R7-2-2 released Kevin Peterson via Tech-talk
Next: Channel connection performance Axel Terfloth via Tech-talk
