1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Autosave PVs showing up as INVALID(UDF_ALARM)
From: "Arnold, Ned D. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Iain Marcuson <[email protected]>
Date: Thu, 4 Feb 2021 22:29:26 +0000
> Is there a way to slow down the fanout processing,
The sequence record allows you to add delays for each step, and it has more links than the fanout record. You would probably add a delay before Link 0 and "0" delay for the rest.
   Ned
From: Tech-talk <[email protected]> on behalf of Iain Marcuson via Tech-talk <[email protected]>
Sent: Thursday, February 4, 2021 04:26 PM
To: Mooney, Tim M. <[email protected]>; [email protected] <[email protected]>
Subject: RE: Autosave PVs showing up as INVALID(UDF_ALARM)
I checked that the PROC field does process the record, and it does.  I mistyped the fanout record name at startup, which is why those were not propagating, but they are now and I do not have an issue with undefined records.  My problem is now that the records are not propagating to the hardware.  If I process an individual record, the value propagates, but not when I run the fanout record.  Is there a way to slow down the fanout processing, or is this a job for the sequencer?
Thank you,
Iain.
Sent: Wednesday, February 03, 2021 2:59 PM
To: [email protected]; Iain Marcuson <[email protected]>
Hi Iain,
You could try writing to the PROC field to verify that processing the record clears the UDF field.  If it does, then you could set the TPRO field in the database, and reboot, to check that the fanout record is actually processing the record.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Wednesday, February 3, 2021 1:11 PM
To: [email protected] <[email protected]>
Subject: Autosave PVs showing up as INVALID(UDF_ALARM)
I am using autosave in an IOC.  Several PVs show up as INVALID(UDF_ALARM).  Autosave is set to restore in pass 1, and the PVs appear to be in the autosave .sav files.  In addition, I use a series of fanout records to try to force processing of the PVs, although I again get the Undefined status.  Are there any items I can check to try to resolve this?
Thank you,
Iain Marcuson
Software Engineer, Sydor Technologies
585.278.1168 | www.SydorTechnologies.com
Skype: [email protected]
Autosave PVs showing up as INVALID(UDF_ALARM) Iain Marcuson via Tech-talk
Re: Autosave PVs showing up as INVALID(UDF_ALARM) Mooney, Tim M. via Tech-talk
RE: Autosave PVs showing up as INVALID(UDF_ALARM) Iain Marcuson via Tech-talk
Prev: RE: Autosave PVs showing up as INVALID(UDF_ALARM) Iain Marcuson via Tech-talk
Next: Question about databrowser of CSS lzf neu via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Migrating S7 PLCs to S7-1500 Abdalla Ahmad via Tech-talk
