> However, in terms of the network bandwidth I think PVA and CA will be the same.
Unless of course one is using compression which PVA supports but CA does not. In that case PVA can significantly reduce the required bandwidth. For example areaDetector supports JPEG compression of NTNDArrays. That can easily reduce the bandwidth by a factor of 10 while not significantly impacting image quality.
-----Original Message-----
Sent: Wednesday, February 10, 2021 11:41 AM
To: 'Manoussakis, Adamandios' <[email protected]>
Cc: [email protected]
Subject: RE: Estimate Data Rate and BW requirements
> It seems like for large number of arrays PVA in epics 7 might be the better way to go? Is just due to the way the data is stored and transferred with PVA vs CA?
There are definitely advantages to PVA vs CA for arrays: support for multi-dimensional arrays, run-time changing of the data type and array size, metadata transferred atomically with the array data, etc. areaDetector supports transporting NTNDArrays with pvAccess, and the ImageJ viewer supports this, including compressed arrays.
Sent: Wednesday, February 10, 2021 11:36 AM
To: Mark Rivers <[email protected]>
Sent: Tuesday, February 9, 2021 1:39 PM
To: Manoussakis, Adamandios <[email protected]>
Subject: Re: Estimate Data Rate and BW requirements
I think the bandwidth requirements depend almost entirely on the number of large arrays you will be sending via Channel Access. If you use areaDetector and Channel Access to transport arrays from an IOC to a client viewer you can easily consume 100% of GigE bandwidth. If you have a display with 1000 scaler PVs each changing at 10Hz that will only be 80kB/s (plus overhead), so it is less than 0.1% of GigE bandwidth.
From: Tech-talk <[email protected]> on behalf of Manoussakis, Adamandios via Tech-talk <[email protected]>
Sent: Tuesday, February 9, 2021 3:04 PM
To: [email protected]
Subject: Estimate Data Rate and BW requirements
Hello All,
Trying to understand a few things on data rate and bandwidth with regards to epics. Most of epics is based off UDP/TCP, so I was thinking that your max will be related to TCP throughput calculations?
Is there a rule of thumb for epics on estimating BW requirements?
If the infrastructure is there to transmit and no BW issues what is the upper limit for data rate given a number of PVs?
Is there an upper limit depending on PVs and there sizes when doing transfers like caget?
Thanks
- Estimate Data Rate and BW requirements Manoussakis, Adamandios via Tech-talk
- Re: Estimate Data Rate and BW requirements Mark Rivers via Tech-talk
- RE: Estimate Data Rate and BW requirements Manoussakis, Adamandios via Tech-talk
- RE: Estimate Data Rate and BW requirements Mark Rivers via Tech-talk
Issue with record processing and being able to process records after a certain amount of delay Wang, Andrew via Tech-talk
<2021>
2025
2026
Question about option MaxPermSize for CSS lzf neu via Tech-talk
<2021>
2025
2026
