Hi Ben,
> Suppose we have been at the target position for some time, i.e.
> VAL=OVAL, so that E(n)=0 for all n. Then all terms become 0 and the
> output is OVAL=0 as well. But shouldn't it be OVAL=VAL instead?
I think your statement that "all terms become 0" is incorrect. The integral term (I) does not become zero even when sitting at the desired setpoint for infinite time, because it is the integral from time=T0, where T0 is the time that the feedback was turned on. The integral term is what prevents "droop", e.g. it is what supplies the constant power required to keep a furnace at 500 C even when the error is 0.
Your statement that "we have been at the target position for some time, i.e. VAL=OVAL" is also incorrect. When it is at the target position VAL=CVAL, not OVAL.
I use the EPID record for lots of tasks and it seems to work fine. Have you observed an issue which led you to post this message?
From: Tech-talk <[email protected]> on behalf of Ben Franksen via Tech-talk <[email protected]>
Sent: Saturday, February 13, 2021 3:53 AM
To: EPICS tech-talk
Subject: Re: EPID Record
Oops, sorry for the botched subject.
Am 13.02.21 um 10:50 schrieb Ben Franksen via Tech-talk:
> I have a question regarding the epid record type, which is part of
> https://github.com/epics-modules/std.
> According to the docs, the formula to calculate the output is
> OVAL = P + I + D
> P = KP * E(n)
> I = KP * KI * SUMi ( E(i) * dT(n) )
> D = KP * KD * ( (E(n) - (E(n-1) ) / dT(n) )
> I checked that the code (in the soft device support) really does that. I
> am ignoring the extra functionality that limits the output to be between
> DRVL and DRVH as this is irrelevant here.
> Either I am mising something here or this is a bug and line 171 of
> stdApp/src/devEpidSoft.c should not be
> oval = p + i + d;
> but rather
> oval += p + i + d;
> and the formula above start with
> OVAL += P + I + D
> Cheers
> Ben
I would rather have questions that cannot be answered, than answers that
cannot be questioned. -- Richard Feynman
- Re: EPID Record Ben Franksen via Tech-talk
- EPICS Record Ben Franksen via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
