> That means KI must *always* be non-zero.
No, that's not true. Consider the case of DC motor where the EPID output is a DAC that controls the motor velocity. If the VAL field is the motor position, then when the motor is at the target position the velocity is 0, so the I term must be 0.
From: Tech-talk <[email protected]> on behalf of Ben Franksen via Tech-talk <[email protected]>
Sent: Saturday, February 13, 2021 5:44 PM
Cc: [email protected]
Subject: Re: EPID Record
Hi Mark
I slightly re-arranged your reply.
Am 13.02.21 um 13:32 schrieb Mark Rivers:
>> Suppose we have been at the target position for some time, i.e.
>> VAL=OVAL, so that E(n)=0 for all n. Then all terms become 0 and the
>> output is OVAL=0 as well. But shouldn't it be OVAL=VAL instead?
> Your statement that "we have been at the target position for some
> time, i.e. VAL=OVAL" is also incorrect. When it is at the target
> position VAL=CVAL, not OVAL.
Yes, sorry, I have confused OVAL and CVAL here.
> I think your statement that "all terms become 0" is incorrect. The
> integral term (I) does not become zero even when sitting at the
> desired setpoint for infinite time, because it is the integral from
> time=T0, where T0 is the time that the feedback was turned on.
So that means if we start the feedback when E=VAL-CVAL=0 then we will
first move the system *away* from the desired VAL (unless it happens to
be equal to zero). Then we accumulate the errors, increasing I at each
step, until after a while I is large enough to compensate our initial error.
That means KI must *always* be non-zero. I find it a bit strange that it
initially has to move away from the correct output value only to arrive
at that value some steps later. Is it possible to preload the I with a
non-zero value if one has a good guess what its initial value should be?
> The integral term is what prevents "droop", e.g. it is what supplies
> the constant power required to keep a furnace at 500 C even when the
> error is 0.
Ok, I think I understand this now. Thanks.
> I use the EPID record for lots of tasks and it seems to work fine.
> Have you observed an issue which led you to post this message?
Not me personally. Some physicists wanted to understand the behavior of
one of our control loops better, looked at the formula and came up with
the above objection. I agree that with a non-zero KI it should work
(after enough initial cycles).
Cheers
Ben
I would rather have questions that cannot be answered, than answers that
cannot be questioned. -- Richard Feynman
- Re: EPID Record Ben Franksen via Tech-talk
- EPICS Record Ben Franksen via Tech-talk
- Re: EPID Record Mark Rivers via Tech-talk
ELMO motion control using EPICS Abdalla Ahmad via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
