Subject: LUA: luascript record
From: Kuldeep Joshi via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 19 Feb 2021 08:56:49 +0000
Hello,
I have some questions regarding the luascript record.
I am using luascript record which is being loaded via a dbLoadRecords call from the iocsh.
I wish to modify the CODE field during operation. I have configured RELO to Every Processing
I am having a separate luascript file which is invoked from the CODE field.
1) When the record.PROC is initiated from the phoebus the gui freezes till the complete script gets executed. Is the CA set to PROC field a blocking call??
2) After the completion of execution all the missed data is seen in phoebus databrowser. I guess the data is captured but the GUI is not refreshed.
3) will handling of the luascript record in a separate thread help (ie in IOC or phoebus)?? lets say using something like luaspawn.
4) can we use pcall for handling exceptions/errors. As from my experience I see that the record processing freezes in case of any exception(say a nil value access)/errors even write to FRLD is not helping. That can we recover from exceptions in luascript record without restarting the IOC?
Any other way to solve the issue will also be welcomed.
Regards and thank you in advance
Kuldeep Joshi
Prev: RE: Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
Next: Re: Accessing waveform record values in C Hu, Yong via Tech-talk
Prev: Re: 回复: 回复: How to capture messages generated by PyEpics? Michael Davidsaver via Tech-talk
Next: Alive Server Installation Smith, William via Tech-talk
