Subject: Alive Server Installation
From: "Smith, William via Tech-talk" <[email protected]>
Date: Fri, 19 Feb 2021 16:20:12 +0000
Hi Dohn,
I have been trying to install an alive server (https://epics-alive-server.github.io/). I have followed the various installation files in each repository. First I pulled and installed the alive daemon and ran it successfully. (https://github.com/epics-alive-server/alived)
When I ping it I get:
emil@sissy-serv-04:~/alive$ sudo alivectl -p
up
Next I wanted to install the web server, for that I pulled the following repositories:
https://github.com/dohnarms/dcgi.git
https://github.com/epics-alive-server/client-tools.git
In both directories I did nothing other than “sudo make install”. In both cases I used sudo because the output was being written to /usr/local/ This seemed to work ok, everything was installed and I got no error messages. Finally I pulled the repo https://github.com/epics-alive-server/web-client.git Again I followed the installation instructions, deciding not to change anything because I had installed the requirements in the previous step. This created an executable
/usr/local/cgi-bin/ioc_alive.cgi
If I try and run this
./ioc_alive.cgi
I get the error:
*** buffer overflow detected ***: terminated
Aborted (core dumped)
Any ideas?
All the best,
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Re: Alive Server Installation Arms, Dohn A. via Tech-talk
Prev: Re: Accessing waveform record values in C Hu, Yong via Tech-talk
Next: Re: Alive Server Installation Arms, Dohn A. via Tech-talk
Prev: LUA: luascript record Kuldeep Joshi via Tech-talk
