Subject: RE: Accessing waveform record values in C
From: "Dudley, David via Tech-talk" <[email protected]>
Date: Fri, 19 Feb 2021 21:25:40 +0000
If all you’re trying to do is to read elements of the waveform, couldn’t you also use the “Channel Filters” functions that allow access to the elements directly?
I use those all the time in cs-studio displays.
They’re outlined here: <filters (anl.gov)>.
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd@frib.msu.edu
cid:image002.jpg@01D07041.57B6D750
From: Tech-talk <[email protected]> On Behalf Of Hu, Yong via Tech-talk
Sent: Friday, February 19, 2021 11:15 AM
To: Andy Foster <[email protected]>; Wang, Andrew <[email protected]>
Cc: [email protected]
Subject: Re: Accessing waveform record values in C
[EXTERNAL] This email originated from outside of FRIB
Another way without any C codes: use “subArray” record(s) to extract individual element(s) from a waveform record.
record(subArray, "second_element")
              field(INP, "waveform_record CP")
              field(FTVL, "CHAR")
              field(MALM, "250")
              field(NELM, 1)
              field(INDX, 1)
See this for details (or search other website): https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_SubArray
HTH,
Yong Hu
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: Andy Foster <[email protected]>
Date: Thursday, February 18, 2021 at 3:22 AM
To: "Wang, Andrew" <[email protected]>
Hi Andy,
Have you set the field type of field "A" in the aSub record to CHAR? FTA set to CHAR.
Cheers, Andy
On Thu, 18 Feb 2021, 05:23 Wang, Andrew via Tech-talk, <[email protected]> wrote:
All,
Basically I have a waveform record that contains ASCII values of chars shown below.
record(waveform, "waveform_record")
              field(DESC, "")
              field(SCAN, "Passive")
              field(FTVL, "CHAR")
              field(NELM, 250)
When I input caget waveform_record, I get:
waveform_record 250 72 101 108 108 111 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0.
My goal is to access 72, 101, 108, 108, and 111 in a C code for an asub record.
record(aSub, "asub_record")
              field(DESC, "")
              field(SNAM, "c_code")
              field(INPA, "waveform_record")
              field(NOA, 250)
In my C code, I attempt to access the waveform record.
char *waveform_record = (char *)prec->a;
printf("%s\n", waveform_record);
The terminal only prints out 72, the first element. But when I try to do
printf("%s\n", *(waveform_record + 4));
I get a segmentation fault rather than 111. Any advice on how I could potentially access the other elements in the waveform record? Feel like I am missing something very basic here.
Andy
Accessing waveform record values in C Wang, Andrew via Tech-talk
Re: Accessing waveform record values in C Andy Foster via Tech-talk
Re: Accessing waveform record values in C Hu, Yong via Tech-talk
Prev: Re: Alive Server Installation Arms, Dohn A. via Tech-talk
Next: Matlab 2020b crashes with labCA 3.7.2 Miroslaw Dach via Tech-talk
Prev: Re: Accessing waveform record values in C Hu, Yong via Tech-talk
Next: Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
