Subject: RE: Saving hdf5 ADPilatus images along with ROI and stats data from the same frame
From: "Ivashkevych, Oksana via Tech-talk" <[email protected]>
Date: Tue, 23 Feb 2021 16:32:51 +0000
Hi Mark,
They are interested in total counts and max_count from their 4 ROIs. ROI_Start, and ROI_SIZE I can take from “EPICS_PV”.
I understand same things can be archived with ROIStats, which would be fine too.
Thank you
Oksana
> -----Original Message-----
> From: Mark Rivers <[email protected]>
> Sent: Tuesday, February 23, 2021 11:21 AM
> To: Ivashkevych, Oksana <[email protected]>
> Cc: [email protected]
> Subject: Re: Saving hdf5 ADPilatus images along with ROI and stats data from
> the same frame
> Hi Oksana,
> type=PARAM can only be used for parameters generated by that plugin or
> driver, not by other plugins.
> However, you may be able to do what you want by changing your plugin
> chain.
> - Can you please diagram you plugin chain?
> - Are you using both the NDPluginStats and NDPluginROIStats plugin?  If so, is
> this necessary?
> - Is the HDF5 file saving the entire image, or just a specific ROI?
> Mark
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Ivashkevych,
> Oksana via Tech-talk <[email protected]>
> Sent: Tuesday, February 23, 2021 10:05 AM
> To: Tech-talk
> Subject: Saving hdf5 ADPilatus images along with ROI and stats data from the
> same frame
> Hello,
> I am trying to configure hdf5 plugin to save N images with 4 ROI data (start,
> size), and 4 Stats, connected to ROIs ( total , maxValue).
> I have created Attributes.xml file  following example from ADSimDetector.
> type="EPICS_PV" works, however type="PARAM" does not for parameters
> from areaDetector/ADCore/ADApp/pluginSrc/, but does work for params
> from areaDetector/ADCore/ADApp/ADSrc/.
> It looks like with "EPICS_PV" type statistics data come from the previous
> frame.
> I was wondering if there is something I am missing, or there are other ways
> to get the correct statistics into the hdf5 file. I have tried using Stats,
> ROIStats, and ROI plugins.
> The green attributes are correctly saved, others show NaN in hdf5 file.
> I have ADCore 3.6.0; ADPilatus 2.6.0
> Thank you
> Attributes.xml:
> <?xml version="1.0" standalone="no" ?>
> <!-- Attributes -->
> <Attributes
>     xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="../../../../../ADCore/XML_schema/NDAtt
> ributes.xsd"
>     <Attribute name="DriverFileName"  type="PARAM"
> source="FULL_FILE_NAME"                       datatype="STRING"
> description="Driver file name"/>
>     <Attribute name="ROI0Size"      type="PARAM"    source="DIM0_SIZE"
> datatype="INT"     description="X size ROI 0"/>
>     <Attribute name="ROI0Mean"      type="PARAM"
> source="MEAN_VALUE"              datatype="DOUBLE"     description="Mean
> value ROI 0"/>
>     <Attribute name="ROI1Mean"      type="PARAM"
> source="MEAN_VALUE" addr="1"     datatype="DOUBLE"
> description="Mean value ROI 0"/>
>     <Attribute name="_ROI0Total"     type="PARAM"
> source="ROISTAT_TOTAL"                   datatype="DOUBLE"     description="Total
> counts ROI 0"/>
>     <Attribute name="_ROI1Total"     type="PARAM"
> source="ROISTAT_TOTAL"      addr="1"     datatype="DOUBLE"
> description="Total counts ROI 1"/>
>     <Attribute name="MaxSizeX"            type="PARAM"
> source="MAX_SIZE_X"                   datatype="INT"        description="Detector X
> size"/>
>     <Attribute name="MaxSizeY"            type="PARAM"
> source="MAX_SIZE_Y"                   datatype="INT"        description="Detector Y
> size"/>
>     <Attribute name="CameraModel"         type="PARAM"    source="MODEL"
> datatype="STRING"     description="Camera model"/>
>     <Attribute name="AttributesFileParam"  type="PARAM"
> source="ND_ATTRIBUTES_FILE"            datatype="STRING"
> description="Attributes file param"/>
>     <Attribute name="CameraManufacturer"  type="PARAM"
> source="MANUFACTURER"                 datatype="STRING"
> description="Camera manufacturer"/>
> </Attributes>
RE: Saving hdf5 ADPilatus images along with ROI and stats data from the same frame Mark Rivers via Tech-talk
Saving hdf5 ADPilatus images along with ROI and stats data from the same frame Ivashkevych, Oksana via Tech-talk
Re: Saving hdf5 ADPilatus images along with ROI and stats data from the same frame Mark Rivers via Tech-talk
Prev: Re: Saving hdf5 ADPilatus images along with ROI and stats data from the same frame Mark Rivers via Tech-talk
Next: RE: Saving hdf5 ADPilatus images along with ROI and stats data from the same frame Mark Rivers via Tech-talk
