Subject: Writing/Reading PVs from/to a DB Question
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
Date: Wed, 10 Mar 2021 23:30:45 +0000
Hello All,
I have a few questions about access to PVs from an outside DB and CSS
  1. Is there an option to read/write directly to a PV from a database such as rethinkdb or mariadb?
  2. Is there an option for an IOC to read from a DB and then write to the PVs and also write back to the DB?
  3. I did see an option for CSS to connect to a DB through the JDBC, I assume this can read/write from/to that DB or is there another possible way through CSS?
  4. With CSS is it possible to read in a file JSON/XML/Flat to populate GUI elements that then write to their corresponding PVs and in reverse write out to a file?
Adam
Re: Writing/Reading PVs from/to a DB Question Johnson, Andrew N. via Tech-talk
Prev: StreamDevice with waveforms Randall Cayford via Tech-talk
Next: Re: StreamDevice with waveforms Johnson, Andrew N. via Tech-talk
Prev: Re: StreamDevice with waveforms Johnson, Andrew N. via Tech-talk
Next: Re: Writing/Reading PVs from/to a DB Question Johnson, Andrew N. via Tech-talk
