Subject: |
StreamDevice with waveforms |
Randall Cayford via Tech-talk <[email protected]> |
To: |
"Engbretson, Mark S. via Tech-talk" <[email protected]> |
Date: |
Wed, 10 Mar 2021 14:19:45 -0800 |
I’m trying to use StreamDevice to pass a long string to a controller. Since it’s much longer than 40 characters, I’m using a waveform. Here’s the protocol entry (though I’ve tried many other variants of the format specifier):
sety {
# separator = " ";
out “Y(%s)";
in "YOKAY (%s)";
Here’s the db entry:
record (waveform, "$(PREFIX):ydata")
field (DTYP, "stream")
field (INP, "@mems.proto sety $(BUS)")
field (NELM, 100)
field (FTVL, "CHAR")
field (SCAN, Passive)
Using an example:
caput -s mems:ydata “68 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25”
I’ve tried a number of other variants , of course.
What gets sent in this case is “YD”. So it’s pulling the first number, doing a string to integer conversion, then sending that ascii character (D) and ignoring the rest of the string.
Any ideas?
Thanks.
Randall
- Re: StreamDevice with waveforms Johnson, Andrew N. via Tech-talk
Re: RE: Mistaken code problem of file path in plugin NDFileTIFF shenzb--- via Tech-talk
Writing/Reading PVs from/to a DB Question Manoussakis, Adamandios via Tech-talk
<2021>
2025
2026
STS hiring an IT System Architect-Engineer Hartman, Steven via Tech-talk
<2021>
2025
2026
