Subject: Re: StreamDevice with waveforms
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Randall Cayford <[email protected]>
Cc: "Engbretson, Mark S. via Tech-talk" <[email protected]>
Date: Wed, 10 Mar 2021 23:33:19 +0000
On Mar 10, 2021, at 4:19 PM, Randall Cayford via Tech-talk <[email protected]> wrote:
I’m trying to use StreamDevice to pass a long string to a controller.  Since it’s much longer than 40 characters, I’m using a waveform.  Here’s the protocol entry (though I’ve tried many other variants of the format specifier):
sety {
#  separator = " ";
 out “Y(%s)";
 in "YOKAY (%s)";
Here’s the db entry:
record (waveform, "$(PREFIX):ydata")
   field (DTYP, "stream")
   field (INP, "@mems.proto sety $(BUS)")
   field (NELM, 100)
   field (FTVL, "CHAR")
   field (SCAN, Passive)
Using an example:
caput -s  mems:ydata “68 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25”
I’ve tried a number of other variants , of course.
What gets sent in this case is “YD”.  So it’s pulling the first number, doing a string to integer conversion, then sending that ascii character (D) and ignoring the rest of the string.
Any ideas?
I think you may have mis-read the caput options, you need to use the upper-case S option to put a string to a PV that holds an array of characters, like this:
caput -S mems:ydata "68 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25"
That’s assuming that the string you want to send was exactly what you have in quotes.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
StreamDevice with waveforms Randall Cayford via Tech-talk
Prev: Writing/Reading PVs from/to a DB Question Manoussakis, Adamandios via Tech-talk
Next: Re: Writing/Reading PVs from/to a DB Question Johnson, Andrew N. via Tech-talk
Prev: StreamDevice with waveforms Randall Cayford via Tech-talk
Next: Writing/Reading PVs from/to a DB Question Manoussakis, Adamandios via Tech-talk
