1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Possible to Populate CSS text fields with JDBC calls?
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Ralph Lange <[email protected]>, "Manoussakis, Adamandios" <[email protected]>
Date: Thu, 25 Mar 2021 18:21:23 +0000
> Looking for options to automate filling in of PVs from database values given an input from a user
The control system tools tend to deal with the IOC database via channel access or PV access.
When an operator pushes a button in the middle of the night, we expect that to work right away and not take time while it's connecting to some relational database, maybe fail.
Mind you it's perfectly normal that for example the location of devices and related details is held in some site-specific relational database, and then tools like python are used to create EPICS databases for the IOC records, display files for operator interfaces etc.
But that's done comparably infrequently. Say on a maintenance day, control system engineers might trigger the 'build' of IOC and display configs, restart IOCs etc.
From then on, the IOCs just run and the displays which were generated with info from a relational database are simply files on the disk, they're not re-generated whenever a user pushes a button.
-Kay
Re: Possible to Populate CSS text fields with JDBC calls? Kasemir, Kay via Tech-talk
Possible to Populate CSS text fields with JDBC calls? Manoussakis, Adamandios via Tech-talk
RE: Possible to Populate CSS text fields with JDBC calls? Manoussakis, Adamandios via Tech-talk
Re: Possible to Populate CSS text fields with JDBC calls? Ralph Lange via Tech-talk
Prev: RE: Possible to Populate CSS text fields with JDBC calls? Manoussakis, Adamandios via Tech-talk
Next: Re: Possible to Populate CSS text fields with JDBC calls? Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
