Subject: Re: Changing EPICS general Purpose Thread's Priorities
From: "Kim, Kukhee via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 26 Mar 2021 15:59:52 +0000
Dear Odagiri san,
Long time no see, I am glad to see your message 🙂
> Can I change the priority of "CAS-TCP" thread and "scan-10"
> thread so that the former is given a higher priority than
> that of the latter without modifying any source files in
> base?
It is possible to modify thread priority after the launching process, even possible to modify the scheduling policy (ex, SCHED_OTERH to SCHED_FIFO, to the real-time priority).
Please, check up the followings:
I am using linuxRT - preempted rt patch for this example.
uname -a
Linux cpu-b084-pm01 4.14.139-rt66 #1 SMP PREEMPT RT Mon Sep 30 14:33:17 PDT 2019 x86_64 GNU/Linux
We can check up process id, parent id, thread id, rt-priority, start time, running time, and thread name with the following command.
ps -Leo pid,ppid,tid,rtprio,stime,time,comm
21994 21993 22010      - Mar23 00:00:00 tpg
21994 21993 22011      - Mar23 00:00:00 tpg
21994 21993 22209     59 Mar23 00:00:00 timerQueue
21994 21993 22210     59 Mar23 00:00:00 timerQueue
21994 21993 22212      - Mar23 00:00:00 tpg
21994 21993 22215      - Mar23 00:00:00 tpg
21994 21993 22216     10 Mar23 00:00:00 taskwd
21994 21993 22217     69 Mar23 00:00:00 timerQueue
21994 21993 22218     58 Mar23 00:01:39 cbLow
21994 21993 22219     63 Mar23 00:00:00 cbMedium
21994 21993 22220     70 Mar23 00:00:00 cbHigh
21994 21993 22221     50 Mar23 00:00:00 dbCaLink
21994 21993 22222     98 Mar23 00:12:35 tpgIrqPollingTa
21994 21993 22223     89 Mar23 00:04:02 tpgSoftPollingT
21994 21993 22224     50 Mar23 00:02:59 tpgBsaPollingTa
21994 21993 22225     10 Mar23 00:01:13 tpgRateMeasureP
21994 21993 22226     10 Mar23 00:02:07 tpgDiagnosticsT
21994 21993 22227     50 Mar23 00:02:40 bsaDrvPoll
21994 21993 22228     57 Mar23 00:00:13 timerQueue
21994 21993 22229     66 Mar23 00:00:00 scanOnce
21994 21993 22230     59 Mar23 00:00:00 scan-10
21994 21993 22231     60 Mar23 00:00:00 scan-5
21994 21993 22232     61 Mar23 00:00:01 scan-2
21994 21993 22233     62 Mar23 00:00:07 scan-1
21994 21993 22234     63 Mar23 00:00:14 scan-0.5
21994 21993 22235     64 Mar23 00:00:09 scan-0.2
21994 21993 22236     65 Mar23 00:00:18 scan-0.1
21994 21993 22237     56 Mar23 00:00:00 asCaTask
21994 21993 22238     16 Mar23 00:00:00 CAS-TCP
21994 21993 22239     12 Mar23 00:00:54 CAS-UDP
21994 21993 22240     14 Mar23 00:00:00 CAS-beacon
21994 21993 22241     51 Mar23 00:00:00 CAC-event
21994 21993 22242     10 Mar23 00:00:00 logRestart
21994 21993 22243     10 Mar23 00:00:00 caPutLog
21994 21993 22244     20 Mar23 00:00:24 save_restore
21994 21993 22245     10 Mar23 00:00:00 ipToAsciiProxy
21994 21993 22246     22 Mar23 00:01:42 timerQueue
21994 21993 22247     24 Mar23 00:00:27 CAC-UDP
21994 21993 22250     22 Mar23 00:00:04 CAC-event
21994 21993 22778     18 08:36 00:00:00 CAS-event
21994 21993 22779     20 08:36 00:00:00 CAS-client
22756  6877 22756      - 08:28 00:00:00 dropbear
The 3rd column is thread id, and the 4th column is a priority.  The symbol "-" means no rt-priority for the thread, SCHED_OTHER.
The thread "scan-10" has thread id 22230 and rt-priority 59.
The thread "CAS-TCP" has thread id 22238 and rt-priority 16.
If we want to escalate the rt-priority for those threads, we can do the followings:
# Escalate rt-priority of scan-10 to 60
chrt -f -p 60 22230
pid 22230's current scheduling policy: SCHED_FIFO
pid 22230's current scheduling priority: 59
pid 22230's new scheduling policy: SCHED_FIFO
pid 22230's new scheduling priority: 6
# Escalate rt-priority of CAS-TCP to 20
chrt -f -p 20 22238
pid 22238's current scheduling policy: SCHED_FIFO
pid 22238's current scheduling priority: 16
pid 22238's new scheduling policy: SCHED_FIFO
pid 22238's new scheduling priority: 20
Then, you can see the priorities of those two threads were escalated.
21994 21993 22230     60 Mar23 00:00:00 scan-10        <==========   59 to 60
21994 21993 22238     20 Mar23 00:00:00 CAS-TCP       <========= 16 to 20
I think the help message of the "chrt" will be helpful.
chrt --help
BusyBox v1.31.0 (2019-09-30 13:30:59 PDT) multi-call binary.
Usage: chrt -m | -p [PRIO] PID | [-rfobi] PRIO PROG [ARGS]
Change scheduling priority and class for a process
-m Show min/max priorities
-p Operate on PID
-r Set SCHED_RR class
-f Set SCHED_FIFO class
-o Set SCHED_OTHER class
-b Set SCHED_BATCH class
-i Set SCHED_IDLE class
Thank you.
Best regards,
Kukhee
From: Tech-talk <[email protected]> on behalf of jun-ichi.odagiri--- via Tech-talk <[email protected]>
Sent: Friday, March 26, 2021 12:09 AM
To: [email protected] <[email protected]>
Dear Han san,
Thank you for sending me the information.
I took a look at the site you have let me know.
But, I may be dense, I could not get the point.
It seems like that the information on the site is related
to Multi-Core Linux.
To be more concrete, I tell you what I have in my mind as
follows.
1. A Single-Core CPU is running Linux.
2. Only one IOC program is running on the Linux.
3. The IOC program is multi-threaded, as every one knows.
Here is my question.
base?
Does the site you guided me to answer the question?
Thanks a lot again in advance.
Best regards,
J.Odagiri at KEK.
----- Original Message -----
> Jun-ichi Odagiri san,
> This may be what you are looking for.
> https://github.com/epics-modules/MCoreUtils
> Best,
> Han
> On Thu, Mar 25, 2021 at 4:55 PM jun-ichi.odagiri--- via Tech-talk
> <[email protected]> wrote:
> > Hi, all
> > Do we have a way to change the priorities of the EPICS
> > general purpose threads dynamically on the iocsh?
> > Thanks a lot in advance.
> > Jun-ichi Odagiri(KEK)
Re: Changing EPICS general Purpose Thread's Priorities jun-ichi.odagiri--- via Tech-talk
MRF kernel module, failed to map BARS GAGET Alexis via Tech-talk
Re: MRF kernel module, failed to map BARS Michael Davidsaver via Tech-talk
RE: MRF kernel module, failed to map BARS GAGET Alexis via Tech-talk
Re: Changing EPICS general Purpose Thread's Priorities Jeong Han Lee via Tech-talk
Prev: Re: Changing EPICS general Purpose Thread's Priorities Ralph Lange via Tech-talk
Next: Phoebus lock down BOB Stainer Tom via Tech-talk
Prev: Re: Changing EPICS general Purpose Thread's Priorities Jeong Han Lee via Tech-talk
Next: Re: Changing EPICS general Purpose Thread's Priorities jun-ichi.odagiri--- via Tech-talk
