Subject: Re: Phoebus lock down BOB
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Stainer Tom <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 26 Mar 2021 16:44:13 +0000
>> From now on you can start phoebus with the
>>    -layout /path/to/Example.memento
>> option to open that saved layout.
>I indeed tried saving as a memento file and loaded as you suggest, but it doesn't seem to work and I get the following.
>2021-03-26 17:19:42 WARNING [org.phoebus.ui.application.PhoebusApplication] Ignoring launch parameter '-layout'
>2021-03-26 17:19:42 WARNING [org.phoebus.ui.application.PhoebusApplication] Ignoring launch parameter '/home/user/opi/simple.memento'
>Am I missing something here? I ran it as:
>./phoebus.sh -layout /home/user/opi/simple.memento
The '-layout' option is supported since Feb. 1, https://github.com/ControlSystemStudio/phoebus/pull/1747
I can confirm that it will print that warning because unfortunately that part of the code isn't currently aware of some other part actually handling the option.
So when I try that now, it "works" but there is that warning which should be removed.
And there's no warning when /path/to/example.memento is simply not valid, i.e. no such file.
So bottom line the error handling is terrible, but fundamentally it works when you have a current version of phoebus.
-Kay
Re: Phoebus lock down BOB Kasemir, Kay via Tech-talk
RE: Phoebus lock down BOB Stainer Tom via Tech-talk
Prev: Re: Possible to Populate CSS text fields with JDBC calls? Hu, Yong via Tech-talk
Next: Re: Phoebus lock down BOB Kasemir, Kay via Tech-talk
Prev: RE: Phoebus lock down BOB Stainer Tom via Tech-talk
