Subject: RE: Phoebus lock down BOB
From: Stainer Tom via Tech-talk <[email protected]>
Date: Mon, 29 Mar 2021 07:31:45 +0000
>>> From now on you can start phoebus with the
>> >   -layout /path/to/Example.memento
>>> option to open that saved layout.
>>I indeed tried saving as a memento file and loaded as you suggest, but it doesn't seem to work and I get the following.
>>2021-03-26 17:19:42 WARNING [org.phoebus.ui.application.PhoebusApplication] Ignoring launch parameter '-layout'
>>2021-03-26 17:19:42 WARNING [org.phoebus.ui.application.PhoebusApplication] Ignoring launch parameter '/home/user/opi/simple.memento'
>>Am I missing something here? I ran it as:
>>./phoebus.sh -layout /home/user/opi/simple.memento
> The '-layout' option is supported since Feb. 1, https://github.com/ControlSystemStudio/phoebus/pull/1747
> I can confirm that it will print that warning because unfortunately that part of the code isn't currently aware of some other part actually handling the option.
> So when I try that now, it "works" but there is that warning which should be removed.
> And there's no warning when /path/to/example.memento is simply not valid, i.e. no such file.
> So bottom line the error handling is terrible, but fundamentally it works when you have a current version of phoebus.
> -Kay
Thanks Kay for the advice, however I am still having issues.
After pulling master (including the merged pull request) I no longer get the two warning messages from before, so that’s good!
But it still opens CSS in the same way as opening the BOB file – I can edit the OPI and from the user point of view it is still Phoebus not a single page application that is locked down.
Again, I ran it via the same command.
Is it just my system?
My system is:
·         Fedora 33 (5.10.19-200.fc33.x86_64 #1 SMP Fri Feb 26 16:21:30 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux)
·         openjdk 15.0.2 2021-01-19
·         OpenJDK Runtime Environment 20.9 (build 15.0.2+7)
·         OpenJDK 64-Bit Server VM 20.9 (build 15.0.2+7, mixed mode, sharing)
·         Phoebus master (commit 70b9a4c3a7feefc7cf86c97f328c443af8468fc5)
Kind regards,
Tom
Re: Phoebus lock down BOB Kasemir, Kay via Tech-talk
Phoebus lock down BOB Stainer Tom via Tech-talk
RE: Phoebus lock down BOB Stainer Tom via Tech-talk
Prev: Re: Usage of an EPICS word jun-ichi.odagiri--- via Tech-talk
Next: Re: Usage of an EPICS word Ralph Lange via Tech-talk
Prev: Re: Phoebus lock down BOB Kasemir, Kay via Tech-talk
Next: Re: Phoebus lock down BOB Kasemir, Kay via Tech-talk
