> But it still opens CSS in the same way as opening the BOB file – I can edit the OPI and from the user point of view it is still Phoebus not a single page application that is locked down.
When you run phoebus, you can't do much about the fact that that's what you're running.
If you want something else, you'll have to use something else, for example the web runtime, which will only display/execute *.bob files, without an editor, without a data browser, without probe, pv tree etc.
You can also assemble your own site-specific version of phoebus where you simply don't include the display editor.
Then you won't be able to invoke the editor, so you'll likely need to build two versions:
One that includes the editor so you can create displays, and one without the editor for you end users to have an execute-only version.
As a test, you can simply delete the file lib/app-display-editor-*.jar from the product.
-Kay
- RE: Phoebus lock down BOB Stainer Tom via Tech-talk
- Phoebus lock down BOB Stainer Tom via Tech-talk
- Re: Phoebus lock down BOB Kasemir, Kay via Tech-talk
Re: Rate of change calculation Pietryla, Tony via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
