>> But it still opens CSS in the same way as opening the BOB file - I can edit the OPI and from the user point of view it is still Phoebus not a single page application that is locked down.
>When you run phoebus, you can't do much about the fact that that's what you're running.
> If you want something else, you'll have to use something else, for example the web runtime, which will only display/execute *.bob files, without an editor, without a data browser, without probe, pv tree etc.
> You can also assemble your own site-specific version of phoebus where you simply don't include the display editor.
> Then you won't be able to invoke the editor, so you'll likely need to build two versions:
> One that includes the editor so you can create displays, and one without the editor for you end users to have an execute-only version.
> As a test, you can simply delete the file lib/app-display-editor-*.jar from the product.
> -Kay
That's clear, thanks for clarifying.
Kind regards,
Tom
- Re: Phoebus lock down BOB Tynan Ford via Tech-talk
- Phoebus lock down BOB Stainer Tom via Tech-talk
- Re: Phoebus lock down BOB Kasemir, Kay via Tech-talk
- RE: Phoebus lock down BOB Stainer Tom via Tech-talk
modbus read error Дмитрий Прощенко via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
