Subject: Questions about arrays
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Tue, 30 Mar 2021 03:55:57 +0000
All,
I have two questions pertaining to the array records in EPICS 3.15.
  1. Suppose I have an analog input array or waveform record of size 5 that contains the values 1, 2, 3, 4, 5. Suppose I want to replace with the fourth element. Based upon what I've read, it doesn't seem like subArray is a viable choice. I've also tried to use caput but to no avail. Any recommendations other than using aSub?
  2. Suppose I have eight individual analog input records and I want to "concatenate their values" and store the result into an analog input array record. I'm thinking about using either aCalcout or an aub routine. Are those valid options and if not, what are alternative options I should explore?
Thank you!
Andy
Re: Questions about arrays Mooney, Tim M. via Tech-talk
Re: Questions about arrays Johnson, Andrew N. via Tech-talk
Prev: Re: Usage of an EPICS word jun-ichi.odagiri--- via Tech-talk
Next: Re: Changing EPICS general Purpose Thread's Priorities jun-ichi.odagiri--- via Tech-talk
Prev: Re: Question about ACROMAG IP-408 Wang, SuYin Grass via Tech-talk
Next: Re: Questions about arrays Mooney, Tim M. via Tech-talk
