Subject: Re: Questions about arrays
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Wang, Andrew" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 30 Mar 2021 15:57:35 +0000
Hi Andy,
On Mar 29, 2021, at 10:55 PM, Wang, Andrew wrote:
> I have two questions pertaining to the array records in EPICS 3.15.
> 	• Suppose I have an analog input array or waveform record of size 5 that contains the values 1, 2, 3, 4, 5. Suppose I want to replace with the fourth element. Based upon what I've read, it doesn't seem like subArray is a viable choice. I've also tried to use caput but to no avail. Any recommendations other than using aSub?
Arrays have historically been second-class citizens in the EPICS database, and we don’t have many generic ways of processing them. As you’ve discovered the subArray cannot do what you want by itself.
The latest release of EPICS 7 has added a few improvements to the internals so with that release it’s possible to handle zero-element arrays, and to extract parts of an array using a DB link. We haven’t added any more record types though, so at the moment the aSub and acalcout are the best ways to handle that in the database, or you could use an SNL program but you might want to move more of the array processing into SNL if you do that since moving data between the IOC and the SNL program isn’t particularly efficient.
> 	• Suppose I have eight individual analog input records and I want to "concatenate their values" and store the result into an analog input array record. I'm thinking about using either aCalcout or an aub routine. Are those valid options and if not, what are alternative options I should explore?
I would suggest an aSub for that, it has lots of inputs with links for fetching the individual data points, and should be a bit more efficient than an acalcout although it does mean you would have to write some C code.
Your questions do show that we could do with adding some new record types to Base for handling these kinds of operations.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Questions about arrays William Layne via Tech-talk
Questions about arrays Wang, Andrew via Tech-talk
Prev: Re: Questions about arrays Mooney, Tim M. via Tech-talk
Next: Re: Questions about arrays William Layne via Tech-talk
Prev: Re: Questions about arrays Ralph Lange via Tech-talk
