> According to what you said, what should my definition of SUPPORT look like?
> Is it defined to the epics directory?
Here are 3 options for fixing your RELEASE file.
The first does not use SUPPORT at all.
#SUPPORT=$(TOP)/..
ASYN=/home/lytt/epics/asyn4/asyn4-38
#CALC=/home/lytt/epics/calc/calc_R3-4/calc-3-4
PCRE=/home/lytt/epics/streamdevice/StreamDevice-master/prce/prce2-10.36
The second defines support as an absolute path:
SUPPORT=/home/lytt/epics
ASYN=$(SUPPORT)/asyn4/asyn4-38
#CALC=$(SUPPORT)/calc/calc_R3-4/calc-3-4
PCRE=$(SUPPORT)/streamdevice/StreamDevice-master/prce/prce2-10.36
The third defines support as a relative path:
SUPPORT=$(TOP)/../..
Your original RELEASE file defined support as a relative path, but it was incorrect because it needed one more "/.." because you have a non-standard directory structure under /home/lytt/epics. You also then had the paths relative to SUPPORT wrong, you did not want /home/lytt/epics after $(SUPPORT).
Sent: Friday, April 2, 2021 1:19 AM
To: Mark Rivers
Subject: 回复: CentOS8--An error occurred when installing StreamDevice
Sorry to reply to your message now! According to what you said, what should my definition of SUPPORT look like? Is it defined to the epics directory? My ASYN is an absolute path, and that asyn4-38 is a non-standard directory structure. I did it again with CentOS7, but there will still be such an error. Thank you!
------------------ 原始邮件 ------------------
发件人: "Mark Rivers" <[email protected]>;
发送时间: 2021年4月2日(星期五) 中午12:12
收件人: "回忆回眸"<[email protected]>;
主题: Re: CentOS8--An error occurred when installing StreamDevice
It looks to me like your definition of SUPPORT as $(TOP)/.. is incorrect. That would not point to a directory above home/epics. I suggest you replace the definition of ASYN with its absolute path.
You have a non-standard directory structure where there is an additional asyn4 directory above the asyn4-38 directory.
Sent from my iPhone
On Apr 1, 2021, at 10:22 PM, 回忆回眸 <[email protected]> wrote:
This is the entire content of my RELEASE. Take a look, is there something wrong with the configuration? The installation path of ASYN is the installation path of my asyn. Thank you very much!
#RELEASE Location of external products
# Run "gnumake clean uninstall install" in the application
# top directory each time this file is changed.
# NOTE: The build does not check dependencies on files
# external to this application. Thus you should run
# "gnumake clean uninstall install" in the top directory
# each time EPICS_BASE, SNCSEQ, or any other external
# module defined in the RELEASE file is rebuilt.
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
# If you don't want to install into $(TOP) then
# define INSTALL_LOCATION_APP here
#INSTALL_LOCATION_APP=<fullpathname>
SUPPORT=$(TOP)/..
-include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
ASYN=$(SUPPORT)/home/lytt/epics/asyn4/asyn4-38
#CALC=$(SUPPORT)/home/lytt/epics/calc/calc_R3-4/calc-3-4
PCRE=$(SUPPORT)/home/lytt/epics/streamdevice/StreamDevice-master/prce/prce2-10.36
# EPICS_BASE usually appears last so other apps can override stuff:
EPICS_BASE=/home/lytt/epics/base
# These lines allow developers to override these RELEASE settings
# without having to modify this file directly.
-include $(TOP)/../RELEASE.local
-include $(TOP)/../RELEASE.$(EPICS_HOST_ARCH).local
-include $(TOP)/configure/RELEASE.local
发送时间: 2021年4月2日(星期五) 中午11:09
Please show the contents of the stream/configure/RELEASE file.
There is no need to reinstall asyn.
Sent from my iPhone
On Apr 1, 2021, at 9:15 PM, 回忆回眸 <[email protected]> wrote:
Thanks for your reply! Excuse me, according to what you said, there is a problem with my RELEASE, how should I solve it? Do I want to reinstall the latest version of asyn? Or reconfigure RELEASE? Thank you!
发送时间: 2021年4月2日(星期五) 凌晨0:54
抄送: "EPICS Tech-Talk"<[email protected]>;
主题: RE: CentOS8--An error occurred when installing StreamDevice
I forgot to include tech-talk in my original reply.
> Among them “asyn” has been installed and the asyn installation path is configured in configure/RELEASE.
It really seems like there is a problem with your configure/RELEASE file. If asyn were defined there then it should be in the list of include paths. I have broken the output of your compile command so each -I starts on a new line to make it easier to read.
-I.
-I../O.Common
-I.
-I.
-I..
-I../../include/compiler/gcc
-I../../include/os/Linux
-I../../include
-I/home/lytt/epics/base/include /compiler/gcc
-I/home/lytt/epics/base/include/os/Linux
Note that it is not searching the asyn directory.
This is what I get when I compile on Centos8:
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -DUSE_TYPED_RSET -DSTREAM_INTERNAL -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common
-I.
-I.
-I..
-I../../include
-I/corvette/home/epics/devel/asyn-4-41/include
-I/corvette/home/epics/devel/calc-3-7-3/include
-I/corvette/usr/local/epics-devel/base-7.0.5/include/compiler/gcc
-I/corvette/usr/local/epics-devel/base-7.0.5/include/os/Linux
-c ../AsynDriverInterface.cc
Note that it is searching in asyn-4-41.
From: Tech-talk <[email protected]<mailto:[email protected]>> on behalf of 回忆回眸 via Tech-talk <[email protected]<mailto:[email protected]>>
Sent: Thursday, April 1, 2021 1:50 AM
To: tech-talk
Subject: CentOS8--An error occurred when installing StreamDevice
Hello, I got the following error when installing StreamDevice:
Compilation is interrupted.
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -DUSE_TYPED_RSET -DSTREAM_INTERNAL -O3 -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I.- I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/home/lytt/epics/base/include /compiler/gcc -I/home/lytt/epics/base/include/os/Linux -I/home/lytt/epics/base/include -c ../AsynDriverInterface.cc
../AsynDriverInterface.cc:41:10: Fatal error: asynDriver.h: No such file or directory
#include "asynDriver.h"
Among them “asyn” has been installed and the asyn installation path is configured in configure/RELEASE. How can I solve this? Thank you!
- CentOS8--An error occurred when installing StreamDevice liu1516301092
- RE: CentOS8--An error occurred when installing StreamDevice Mark Rivers via Tech-talk
Re: Question on Multiple Instruments in one IOC or Multiple IOCs for each Manoussakis, Adamandios via Tech-talk
RE: 回复: 回复: CentOS8--An error occurred when installing StreamDevice Mark Rivers via Tech-talk
<2021>
2025
2026
L&C Science and Technology RH-200 Device Support Taufer, Gary via Tech-talk
<2021>
2025
2026
