Subject: RE: CentOS8--An error occurred when installing StreamDevice
To: 回忆回眸 <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 1 Apr 2021 16:54:09 +0000
I forgot to include tech-talk in my original reply.
> Among them “asyn” has been installed and the asyn installation path is configured in configure/RELEASE.
It really seems like there is a problem with your configure/RELEASE file.  If asyn were defined there then it should be in the list of include paths.  I have broken the output of your compile command so each -I starts on a new line to make it easier to read.
-I.
-I../O.Common
-I.
-I.
-I..
-I../../include/compiler/gcc
-I../../include/os/Linux
-I../../include
-I/home/lytt/epics/base/include /compiler/gcc
-I/home/lytt/epics/base/include/os/Linux
Note that it is not searching the asyn directory.
This is what I get when I compile on Centos8:
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux    -DUSE_TYPED_RSET -DSTREAM_INTERNAL   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common
-I.
-I.
-I..
-I../../include
-I/corvette/home/epics/devel/asyn-4-41/include
-I/corvette/home/epics/devel/calc-3-7-3/include
-I/corvette/usr/local/epics-devel/base-7.0.5/include/compiler/gcc
-I/corvette/usr/local/epics-devel/base-7.0.5/include/os/Linux
-c ../AsynDriverInterface.cc
Note that it is searching in asyn-4-41.
From: Tech-talk <[email protected]> on behalf of 回忆回眸 via Tech-talk <[email protected]>
Sent: Thursday, April 1, 2021 1:50 AM
To: tech-talk
Subject: CentOS8--An error occurred when installing StreamDevice
Hello, I got the following error when installing StreamDevice:
Compilation is interrupted.
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -DUSE_TYPED_RSET -DSTREAM_INTERNAL -O3 -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I.- I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/home/lytt/epics/base/include /compiler/gcc -I/home/lytt/epics/base/include/os/Linux -I/home/lytt/epics/base/include -c ../AsynDriverInterface.cc
../AsynDriverInterface.cc:41:10: Fatal error: asynDriver.h: No such file or directory
  #include "asynDriver.h"
    Among them “asyn” has been installed and the asyn installation path is configured in configure/RELEASE. How can I solve this? Thank you!
CentOS8--An error occurred when installing StreamDevice liu1516301092
Prev: Re: Questions about arrays Ralph Lange via Tech-talk
Next: RE: Question on Multiple Instruments in one IOC or Multiple IOCs for each Manoussakis, Adamandios via Tech-talk
Prev: Re: CentOS8--An error occurred when installing StreamDevice Johnson, Andrew N. via Tech-talk
Next: Re: 回复: CentOS8--An error occurred when installing StreamDevice Mark Rivers via Tech-talk
