On 4/15/21 9:26 AM, Manoussakis, Adamandios via Tech-talk wrote:
> I was looking mostly into the epics.camonitor or the auto_monitor parameter (seems like camonitor just when you create the pv you can set this?) in pyepics. The python script is just a small file generator that does some basic calculations. I was trying to have CSS just call it to run to avoid having another application to deal with. Either by pressing a button (execute command works fine but cannot get the execute to trigger based off a rule that I know of) or by a pv changing value and css calling the script (jython doesn’t work with numpy/pandas).
Remember that with cs-studio, as with any CA client, there may be multiple instances running
on the same, or different computers.
Also, you might consider separating the online calculation from the data logging.
Putting the result of your calculation into another PV would give you the option
of seeing the live result.
- Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
- Re: Python Script call from Button press, module not found Kasemir, Kay via Tech-talk
- RE: Python Script call from Button press, module not found Manoussakis, Adamandios via Tech-talk
- Re: Python Script call from Button press, module not found Matt Newville via Tech-talk
- Re: Python Script call from Button press, module not found Johnson, Andrew N. via Tech-talk
Re: [EXTERNAL] Python Script call from Button press, module not found Hartman, Steven via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
