From: Michael Davidsaver <[email protected]>, Thursday, April 15, 2021 14:47
>On 4/13/21 11:29 PM, Ru Igarashi via Tech-talk wrote:
>> [normally, I'd inline my response but I'm stuck with Web Outlook. My apologies.]
> Hello Andrew,
>> re: camonitor: the errant sequence is the same with and without camonitor
>> running in parallel. My thinking was that the reliance on the Channel
>> Access monitors meant that update occasionally necessarily would
>> eventually be out of sync. ...
> I don't think anyone else addressed this point specifically,
> and I think it is an important point to make. CA (and PVA)
> subscriptions should always, eventually, be "in-sync". This is an
> essential property for a robust distributed control system to have!
Subscriptions and even caget(), so far, are not impacted with the
observed problem, and, up until I ran my tests on one very specific
configuration, asynchronous caput() weren't affected (at least to
nowhere near this extent). Then I ran on this one very specific
configuration and observed a huge uptick in failed updates in
asynchronous caputs. I think I've simply run across an odd
combination of processor, OS and EPICS versions. I'm just trying
to determine what I need to change to make it work.
> If a PV produces a burst of updates which exceeds some internal
> buffers, the most recent update will never be discarded. So all
> clients will eventually receive the most recent update produced.
I'm seeing that even when the asynchronous caput fail to update
properly: immediate caget after put are updating properly. I have
yet to run my tests on camonitors. That is, EPICS is not failing in
that regard, either.
ru
- problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
- Re: problems with running EPICS Gateway on virtual machines? Hugo Slepicka via Tech-talk
- Re: External: Re: problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
- Re: External: Re: problems with running EPICS Gateway on virtual machines? Johnson, Andrew N. via Tech-talk
- Re: problems with running EPICS Gateway on virtual machines? Ru Igarashi via Tech-talk
- Re: problems with running EPICS Gateway on virtual machines? Michael Davidsaver via Tech-talk
Re: Fanout and asub interaction issues Wang, Andrew via Tech-talk
<2021>
2025
2026
Re: External: Re: problems with running EPICS Gateway on virtual machines? Ralph Lange via Tech-talk
<2021>
2025
2026
