P.S. I commented out the field containing the asub record from the fan out record and processed it. All the waveform records (formerly aai) contained the correct values after I ran caget on them.
Get Outlook for iOS
Sent: Friday, April 16, 2021 9:04:26 PM To: Mooney, Tim M. <[email protected]>; EPICS tech-talk <[email protected]> Subject: Re: Fanout and asub interaction issues
Hi Tim,
I just realized I made a typo. I had them as aai records not aao as my pseudo code contained. The aai records are getting the string via a StreamDevice protocol file.
I changed them to waveform but it didn’t work.
Thoughts?
Sent: Friday, April 16, 2021 8:41 PM To: EPICS tech-talk <[email protected]>; Wang, Andrew <[email protected]> Subject: Re: Fanout and asub interaction issues
Hi Andrew,
I would have expected your database to work. Do the aao records use asynchronous device support? How is an aao record getting a string?
In any case, if you have the calc module, you could replace the fanout with a sseq record, which can wait for completion between output links. I would do it like this:
record(sseq, "sseq_rec") {
field(LNK1, "aao_rec_1.PROC CA")
field(WAIT1, "After2")
field(LNK2, "aao_rec_2.PROC CA")
field(WAIT2, "Wait")
field(LNK3, "asub_rec.PROC PP")
This will process aao_rec_1 and aao_rec_2, wait for them both to finish, and then process asub_rec.
I would not use aao records to hold strings. I would use waveform records with FTVL=="CHAR".
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov) Advanced Photon Source, Argonne National Lab From: Tech-talk <[email protected]> on behalf of Wang, Andrew via Tech-talk <[email protected]>
Sent: Friday, April 16, 2021 9:29 PM To: EPICS tech-talk <[email protected]> Subject: Fanout and asub interaction issues All,
I am encountering an interesting problem and would again appreciate your insights.
Essentially, I have a fanout record and asub record that resemble the following pseudocode:
record(fanout, “fanout_rec”) { field(SCAN, “Passive”) field(LNK0, “aao_rec_1”) field(LNK1, “aao_rec_2”) field(LNK2, “asub_rec”) }
record(asub, “asub_rec”) { field(SCAN, “Passive”) field(SNAM, “c_code”) field(INPA, “aao_rec_1”) field(FTVA, “CHAR”) field(NOA, 2048) field(INPB, “aao_rec_2”) field(FTVB, “DOUBLE”) field(NOB, 2048) }
My goal was to first process the first two aao records so they contain the most up-to-date values before processing “asub_rec”. When I attempt to retrieve the values from both aao records within “c_code”, it is getting previous values that they contained prior to their latest processing.
For instance, if “aao_rec_1” contained “hello”, then when I print out “(CHAR*)prec->a” in “c_code”, it prints out nothing. But when I process it again, but with a different value, I print out “hello”, rather than the latest value it has.
I’m beginning to think it might be better to use the PP flag for INPA and INPB like this:
record(asub, “asub_rec”) { field(SCAN, “Passive”) field(SNAM, “c_code”) field(INPA, “aao_rec_1 PP”) field(FTVA, “CHAR”) field(NOA, 2048) field(INPB, “aao_rec_2 PP”) field(FTVB, “DOUBLE”) field(NOB, 2048) }
Any thoughts or suggestions?
Andy
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
