Subject: Re: Fanout and asub interaction issues
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: "Mooney, Tim M." <[email protected]>, EPICS tech-talk <[email protected]>
Date: Sat, 17 Apr 2021 04:04:26 +0000
Hi Tim,
I just realized I made a typo. I had them as aai records not aao as my pseudo code contained. The aai records are getting the string via a StreamDevice protocol file.
I changed them to waveform but it didn’t work.
Thoughts?
Sent: Friday, April 16, 2021 8:41 PM
To: EPICS tech-talk <[email protected]>; Wang, Andrew <[email protected]>
Hi Andrew,
I would have expected your database to work.  Do the aao records use asynchronous device support?  How is an aao record getting a string?
In any case, if you have the calc module, you could replace the fanout with a sseq record, which can wait for completion between output links.  I would do it like this:
record(sseq, "sseq_rec") {
    field(LNK1, "aao_rec_1.PROC CA")
    field(WAIT1, "After2")
    field(LNK2, "aao_rec_2.PROC CA")
    field(WAIT2, "Wait")
    field(LNK3, "asub_rec.PROC PP")
This will process aao_rec_1 and aao_rec_2, wait for them both to finish, and then process asub_rec.
I would not use aao records to hold strings.  I would use waveform records with FTVL=="CHAR".
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Wang, Andrew via Tech-talk <[email protected]>
Sent: Friday, April 16, 2021 9:29 PM
Subject: Fanout and asub interaction issues
All,
I am encountering an interesting problem and would again appreciate your insights.
Essentially, I have a fanout record and asub record that resemble the following pseudocode:
record(fanout, “fanout_rec”)
              field(SCAN, “Passive”)
              field(LNK0, “aao_rec_1”)
              field(LNK1, “aao_rec_2”)
              field(LNK2, “asub_rec”)
record(asub, “asub_rec”)
              field(SNAM, “c_code”)
              field(INPA, “aao_rec_1”)
              field(FTVA, “CHAR”)
              field(NOA, 2048)
              field(INPB, “aao_rec_2”)
              field(FTVB, “DOUBLE”)
              field(NOB, 2048)
My goal was to first process the first two aao records so they contain the most up-to-date values before processing “asub_rec”. When I attempt to retrieve the values from both aao records within “c_code”, it is getting previous values that they contained prior to their latest processing.
For instance, if “aao_rec_1” contained “hello”, then when I print out “(CHAR*)prec->a” in “c_code”, it prints out nothing. But when I process it again, but with a different value, I print out “hello”, rather than the latest value it has.
I’m beginning to think it might be better to use the PP flag for INPA and INPB like this:
              field(INPA, “aao_rec_1 PP”)
              field(FTVA, “CHAR”)
              field(NOA, 2048)
              field(INPB, “aao_rec_2 PP”)
              field(NOB, 2048)
Any thoughts or suggestions?
Andy
Re: Fanout and asub interaction issues Wang, Andrew via Tech-talk
Re: Fanout and asub interaction issues Mooney, Tim M. via Tech-talk
Prev: Re: Fanout and asub interaction issues Mooney, Tim M. via Tech-talk
Next: Re: Fanout and asub interaction issues Wang, Andrew via Tech-talk
