Subject: Re: pv Access setup
From: Дмитрий Прощенко via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Mon, 19 Apr 2021 16:25:43 +0700
Hello, Michael!
CA woks. I've tested softIocPVA and that is what happened:
epics> pvasr
pvAccess Server v7.1.0
Active configuration (w/ defaults)
EPICS_PVAS_INTF_ADDR_LIST = 0.0.0.0:5075
EPICS_PVAS_BEACON_ADDR_LIST = 127.255.255.255
EPICS_PVAS_AUTO_BEACON_ADDR_LIST = NO
EPICS_PVAS_BEACON_PERIOD = 15
EPICS_PVAS_BROADCAST_PORT = 5076
EPICS_PVAS_SERVER_PORT = 5075
EPICS_PVAS_PROVIDER_NAMES = QSRV
pvget -d cnt
2021-04-19T10:59:32.552 Creating datagram socket from: 0.0.0.0:46421.
2021-04-19T10:59:32.552 Broadcast address #0: 127.255.255.255:5076. (unicast)
2021-04-19T10:59:32.552 Setting up UDP for interface 192.168.1.145/255.255.255.0, broadcast 192.168.1.255, dest <none>.
2021-04-19T10:59:32.552 Creating datagram socket from: 192.168.1.145:5076.
2021-04-19T10:59:32.552 Creating datagram socket from: 192.168.1.255:5076.
2021-04-19T10:59:32.553 Setting up UDP for interface 192.168.122.1/255.255.255.0, broadcast 192.168.122.255, dest <none>.
2021-04-19T10:59:32.553 Creating datagram socket from: 192.168.122.1:5076.
2021-04-19T10:59:32.553 Creating datagram socket from: 192.168.122.255:5076.
2021-04-19T10:59:32.553 Creating datagram socket from: 224.0.0.128:5076.
2021-04-19T10:59:32.553 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2021-04-19T10:59:32.553 Sending 49 bytes 0.0.0.0:46421 -> 127.255.255.255:5076.
Waiting...
2021-04-19T10:59:32.793 Sending 49 bytes 0.0.0.0:46421 -> 127.255.255.255:5076.
2021-04-19T10:59:33.272 Sending 49 bytes 0.0.0.0:46421 -> 127.255.255.255:5076.
2021-04-19T10:59:34.230 Sending 49 bytes 0.0.0.0:46421 -> 127.255.255.255:5076.
2021-04-19T10:59:36.146 Sending 49 bytes 0.0.0.0:46421 -> 127.255.255.255:5076.
Timeout
As far as I understand address 127.255.255.255:5076 is right to broadcast. But in my other OS and in your example IP is defined (e.g. 192.168.18.190). Problems is able to receive message due to network setting?
19.04.2021, 00:57, "Michael Davidsaver" <[email protected]>:
On 4/18/21 10:07 AM, Дмитрий Прощенко via Tech-talk wrote:
 Hi all!
 Im writting cpp program to drive a power supply. Use pv Access for connection. Also I created an IOC using makeBaseApp.pl on my Kubuntu and created bd for testing. And all is well. But using other OS whit IOC I found that my program is not working. pvget isnt working too. I was able tofind information on the need to use qsrv:
 myioc_LIBS += qsrv
 myioc_LIBS += pvAccessIOC
 myioc_DBD += PVASeerverRegister.dbd
 myioc_DBD += qsrv.dbd
 executing pvasr on other OS:
This looks correct.
 And pvget or pvput is not working anyway. I used pva2pva (QSRV / pvAccess Gateway) to know about qsrc. What documants shout I pay attention to? What should I fix to keep it working? I would like to use several IOCs, do I need to configure my addresses go them for correct operation?
Can you test with the softIocPVA executable and a simple database?
This should confirm if this is a network issue.
Also, can you confirm that caget also works?
 cat <<EOF > tick.db
 record(calc, "$(P=)cnt") {
   field(INPA, "$(P=)cnt")
   field(CALC, "A+1")
   field(SCAN, "1 second")
 EOF
 $ softIocPVA -d tick.db
 $ pvget -d cnt
 2021-04-18T10:55:41.653 Creating datagram socket from: 0.0.0.0:45045.
 2021-04-18T10:55:41.653 Broadcast address #0: 192.168.1.255:5076. (not unicast)
 2021-04-18T10:55:41.653 Broadcast address #1: 192.168.210.255:5076. (not unicast)
 2021-04-18T10:55:41.653 Setting up UDP for interface 192.168.1.68/255.255.255.0, broadcast 192.168.1.255, dest <none>.
 2021-04-18T10:55:41.653 Creating datagram socket from: 192.168.1.68:5076.
 2021-04-18T10:55:41.653 Creating datagram socket from: 192.168.1.255:5076.
 2021-04-18T10:55:41.653 Setting up UDP for interface 192.168.210.1/255.255.255.0, broadcast 192.168.210.255, dest <none>.
 2021-04-18T10:55:41.653 Creating datagram socket from: 192.168.210.1:5076.
 2021-04-18T10:55:41.653 Creating datagram socket from: 192.168.210.255:5076.
 2021-04-18T10:55:41.653 Creating datagram socket from: 224.0.0.128:5076.
 2021-04-18T10:55:41.653 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
 2021-04-18T10:55:41.653 Sending 49 bytes 0.0.0.0:45045 -> 192.168.1.255:5076.
 2021-04-18T10:55:41.653 Socket sendto to 192.168.1.255:5076 error: Operation not permitted.
 2021-04-18T10:55:41.653 Sending 49 bytes 0.0.0.0:45045 -> 192.168.210.255:5076.
 2021-04-18T10:55:41.653 UDP Client Rx (49) 192.168.210.255:5076 <- 192.168.210.1:45045
 Waiting...
 2021-04-18T10:55:41.654 UDP Client Rx (53) 0.0.0.0:45045 <- 192.168.210.1:58034
 2021-04-18T10:55:41.654 Connecting to PVA server: 192.168.210.1:41685.
 2021-04-18T10:55:41.654 Opening socket to PVA server 192.168.210.1:41685, attempt 1.
 2021-04-18T10:55:41.654 Socket connected to PVA server: 192.168.210.1:41685.
 2021-04-18T10:55:41.654 Acquiring transport to 192.168.210.1:41685.
 2021-04-18T10:55:41.655 Connected to PVA server: 192.168.210.1:41685.
 cnt 2021-04-18 10:55:40.828 38
 2021-04-18T10:55:41.655 Releasing TCP transport to 192.168.210.1:41685.
 2021-04-18T10:55:41.655 TCP socket to 192.168.210.1:41685 is to be closed.
 2021-04-18T10:55:41.655 UDP socket 0.0.0.0:0 closed.
 2021-04-18T10:55:41.655 UDP Client Rx (0) 0.0.0.0:45045 <- 192.168.210.1:58034
 2021-04-18T10:55:41.655 UDP socket 192.168.1.68:5076 closed.
 2021-04-18T10:55:41.655 UDP Client Rx (0) 192.168.1.68:5076 <- <Ukn Addr Type>
 2021-04-18T10:55:41.655 UDP socket 192.168.1.255:5076 closed.
 2021-04-18T10:55:41.655 UDP Client Rx (0) 192.168.1.255:5076 <- <Ukn Addr Type>
 2021-04-18T10:55:41.655 UDP socket 192.168.210.1:5076 closed.
 2021-04-18T10:55:41.655 UDP Client Rx (0) 192.168.210.1:5076 <- <Ukn Addr Type>
 2021-04-18T10:55:41.655 UDP socket 192.168.210.255:5076 closed.
 2021-04-18T10:55:41.655 UDP Client Rx (0) 192.168.210.255:5076 <- 192.168.210.1:45045
 2021-04-18T10:55:41.655 UDP socket 224.0.0.128:5076 closed.
 2021-04-18T10:55:41.655 UDP Client Rx (0) 224.0.0.128:5076 <- <Ukn Addr Type>
 Done
Re: pv Access setup Hu, Yong via Tech-talk
Re: pv Access setup montis via Tech-talk
Re: pv Access setup Michael Davidsaver via Tech-talk
pv Access setup Дмитрий Прощенко via Tech-talk
Prev: Re: pv Access setup Michael Davidsaver via Tech-talk
Next: Re: WIN_32 Marty Kraimer via Tech-talk
Next: Re: pv Access setup Hu, Yong via Tech-talk
