Subject: Re: pv Access setup
To: Дмитрий Прощенко <[email protected]>, Michael Davidsaver <[email protected]>
Date: Mon, 19 Apr 2021 13:43:51 +0000
It seems you are new to the EPICS community. Welcome aboard!
“127.255.255.255” is not the right broadcast. Assuming you are using Linux, the output of /sbin/ifconfig does NOT have “127.255.255.255” as broadcast for the interface “lo”.
To fix your problem, simply DO NOT customize any EPICS_PVAS_* parameters, i.e. remove your settings of EPICS_PVAS_BEACON_ADDR_LIST and EPICS_PVAS_AUTO_BEACON_ADDR_LIST in your IOC. Your pvasr output should look like the following:
EPICS_PVAS_BEACON_ADDR_LIST =
EPICS_PVAS_AUTO_BEACON_ADDR_LIST = YES
BTW, why do you need to write a cpp program to drive a power supply by using pv Access for connection? The classical IOC with CA should probably be able to meet your requirements. With the classical IOC, you probably do not need to write any complicated codes for your application.
Cheers,
Yong
On 4/19/21, 5:26 AM, "Tech-talk on behalf of Дмитрий Прощенко via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
Hello, Michael!
CA woks. I've tested softIocPVA and that is what happened:
epics> pvasr
pvAccess Server v7.1.0
Active configuration (w/ defaults)
EPICS_PVAS_INTF_ADDR_LIST = 0.0.0.0:5075
EPICS_PVAS_BEACON_ADDR_LIST = 127.255.255.255
EPICS_PVAS_AUTO_BEACON_ADDR_LIST = NO
EPICS_PVAS_BEACON_PERIOD = 15
EPICS_PVAS_BROADCAST_PORT = 5076
EPICS_PVAS_SERVER_PORT = 5075
EPICS_PVAS_PROVIDER_NAMES = QSRV
pvget -d cnt
2021-04-19T10:59:32.552 Creating datagram socket from: 0.0.0.0:46421.
2021-04-19T10:59:32.552 Broadcast address #0: 127.255.255.255:5076. (unicast)
2021-04-19T10:59:32.552 Setting up UDP for interface 192.168.1.145/255.255.255.0, broadcast 192.168.1.255, dest <none>.
2021-04-19T10:59:32.552 Creating datagram socket from: 192.168.1.145:5076.
2021-04-19T10:59:32.552 Creating datagram socket from: 192.168.1.255:5076.
2021-04-19T10:59:32.553 Setting up UDP for interface 192.168.122.1/255.255.255.0, broadcast 192.168.122.255, dest <none>.
2021-04-19T10:59:32.553 Creating datagram socket from: 192.168.122.1:5076.
2021-04-19T10:59:32.553 Creating datagram socket from: 192.168.122.255:5076.
2021-04-19T10:59:32.553 Creating datagram socket from: 224.0.0.128:5076.
2021-04-19T10:59:32.553 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2021-04-19T10:59:32.553 Sending 49 bytes 0.0.0.0:46421 -> 127.255.255.255:5076.
Waiting...
2021-04-19T10:59:32.793 Sending 49 bytes 0.0.0.0:46421 -> 127.255.255.255:5076.
2021-04-19T10:59:33.272 Sending 49 bytes 0.0.0.0:46421 -> 127.255.255.255:5076.
2021-04-19T10:59:34.230 Sending 49 bytes 0.0.0.0:46421 -> 127.255.255.255:5076.
2021-04-19T10:59:36.146 Sending 49 bytes 0.0.0.0:46421 -> 127.255.255.255:5076.
Timeout
As far as I understand address 127.255.255.255:5076 is right to broadcast. But in my other OS and in your example IP is defined (e.g. 192.168.18.190). Problems is able to receive message due to network setting?
Re: pv Access setup Hu, Yong via Tech-talk
Re: pv Access setup Michael Davidsaver via Tech-talk
pv Access setup Дмитрий Прощенко via Tech-talk
Re: pv Access setup Дмитрий Прощенко via Tech-talk
Prev: Re: WIN_32 Marty Kraimer via Tech-talk
Next: Re: pv Access setup Hu, Yong via Tech-talk
Prev: Re: pv Access setup Дмитрий Прощенко via Tech-talk
